Rear window water puddling
Old Jan 31, 2006 | 09:12 PM
koaea's Avatar
koaea
Default Rear window water puddling
Ok, I didn't know how to search it, but I've noticed that water puddles at the front of the rear hatch window. Right in the little corner, and close to the bottom of the hydraulic strut, but on the outside of the window.
Seems that there should be a way for this to drain, is something clogged?
Is my description making sense or should I submit a picture?
thanks
Old Jan 31, 2006 | 09:18 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
It's a common problem with the C4. There is an aftermarket kit you can buy and install that is basically is a drain kit. I believe Mid America (and others) sell the kit.
Old Jan 31, 2006 | 10:07 PM
koaea's Avatar
koaea
Found the kit at Mid-America, thanks!
here's the link in case someone else stumbles onto this thread.
http://www.madvet.com/shop?frame=3.761
Joe
Old Jan 31, 2006 | 10:14 PM
MADinAK's Avatar
MADinAK
Glad you found it. If I hadn't of been watching the Prez at the time I would have looked it up for you. I've thought of buying one for mine but can bring myself to drill the holes. Some blow out the water with air, take it for a quick spin, or just wick it out. I normally just wick it out with a papertowel. It's an irritant but looking at a clean Corvette in the driveway makes it all feel better.
Old Jan 31, 2006 | 10:33 PM
bryantbjb's Avatar
bryantbjb
I bought the kit and it is wonderful. No way I was going to drill through the fiberglass so I had the dealership do it. Worth the install and cost. My rear seal was gone and water leaked into the interior as the water pooled in that nook area.
One note. If you install or have someone do it watch that they drill through both (and I mean both) sets of fiberglass or you will find yourself draining water into the interior behind the sun shade trim. Had that issue as well. You have to pull the sun shade trim to verify installation - overall a learning experience.
Good luck.
Old Feb 1, 2006 | 01:44 AM
slicked25's Avatar
slicked25
What if you just drilled the holes without buying the kit? If you can't see it anyway because it's hid by the weatherstrip what difference does it make? I have this problem too and I really notice it when I go to the car wash. The kit with shipping is about 20 bucks versus a drill bit.
Old Feb 1, 2006 | 08:59 AM
kalister1's Avatar
kalister1
The kit comes with a fitting and a hose to direct the water outside the car. Just drilling a hole could let water inside the car?
Old Feb 1, 2006 | 09:05 AM
Red Dwarf's Avatar
Red Dwarf
Get a turkey baster (sp) sucks it right out.
Old Feb 4, 2006 | 01:41 AM
cedrop's Avatar
cedrop
A Turkey baster!!!!! What a great idea.
I can't believe I've been aggravated by this issue so long and the answer is a Turkey baster!!!.....the help I get from this place.
Thanks!!!!!
Old Feb 4, 2006 | 01:49 AM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Originally Posted by slicked25
What if you just drilled the holes without buying the kit? The kit with shipping is about 20 bucks versus a drill bit.
As said earlier, there are two layers of fiberglass you must drill through. And if I remember correctly, you will need to use two drill bits.
Old Feb 4, 2006 | 06:37 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
correct.
Old Feb 4, 2006 | 07:06 AM
Paul Workman's Avatar
Paul Workman
Default I love the simple solutions!!
Man! That calls for a palm slap to the forehead and a good "DOH!"
Like many, I hate the water, but not enough to drill a hole. A turkey baster will appear in my detailing kit asap. Great I-dear!
P.
Old Feb 4, 2006 | 09:19 AM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
...thats what I do , I also use the turkey baster to drain the water out of the under hood ,hood locky thingy ... ...cheap and no drilling on plastic
Old Feb 4, 2006 | 03:07 PM
onedef92's Avatar
onedef92
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Most of us just use a turkey baster or a 600cc syringe and be done with it.
Old Feb 4, 2006 | 05:19 PM
AZC4Guy's Avatar
AZC4Guy
It hasn't rained here in well over 100 days. This is one vette problem I don't have!!! wheeeeeeeeee!
Old Feb 4, 2006 | 05:45 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
What is it about drilling a hole?
Its not like your putting the hole in the center of the hood. This hole and drain kit is almost invisible when installed! And the inconvience of using turkey basters and leaf blowers......
All you need to do is have faith in yourself, and a long drill.
Old Feb 5, 2006 | 04:14 AM
slicked25's Avatar
slicked25
Well, I guess I'll buy the kit. Everytime I go to wash the car I always have to clean/dry the inside of the back glass. I noticed the weatherstrip where the water will pool up in the corner was loose. I got some black GM adhesive and thought maybe that would fix the water from blasting inside the car or those two corners where the kit will go would keep the water out. Nope. In fact using the glue didn't make any difference what so ever.
It must have been a Friday at the plant
Old Feb 5, 2006 | 09:45 AM
Red Tornado's Avatar
Red Tornado
I just use a $3.00 turkey baster as well.
I hardly have to do it, ever since I replaced my rear hatch weatherstripping. The original one broke down at the corners and
I was getting those infamous puddles as well. But with new (aftermarket) stripping, the puddles are small, and a quick job with the turkey baster is all it takes.
I would never drill holes anywhere on the body of my vette. To do so would be blasphemy
Old Feb 5, 2006 | 11:23 AM
Z-07 freak's Avatar
Z-07 freak
Originally Posted by DINO
I also use the turkey baster to drain the water out of the under hood ,cheap and no drilling on plastic.
Originally Posted by Hot Rod 90
I would never drill holes anywhere on the body of my vette. To do so would be blasphemy.
Chickens
To Rear window water puddling
