Please help
Old Jan 31, 2006 | 10:02 PM
TPI BOY's Avatar
TPI BOY
Default Please help
I installed a o2 sensor on the left hand side because I had a slight miss
So I have two o2 sensors left and right I have duel exhaust. The right reads normal, the left
reads lean,it does not register on my gauge until I punch it, then
it matches the the right side gauge. I installed new injectors thinking
I may have a problem with the old ones, It didn't change anything. If
it's not injectors what would cause the lean problem only on one side.
Old Jan 31, 2006 | 11:22 PM
TPI BOY's Avatar
TPI BOY
ttt
Old Feb 1, 2006 | 04:29 PM
TPI BOY's Avatar
TPI BOY
Anyone
Old Feb 1, 2006 | 04:39 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Need more info any mods?Why did you replace the one?What is the maintenance history in the recent past?What kind of injectors?
It took me a while to get it but it is always best to do the proper troubleshooting before swapping parts.Do you have a factory service manual?If not go to www.helminc.com and oder one it is the best money you can buy for the car.
And read the Tech FAQ at the top.It is hard to help if we don't know what year you have.
To Please help
