From: SCMR Rat Pack'r Charter Member..Great Bend KS
Mine leaned 3/4" to the left.
Killebrew told me "That's within specs."
Some have tried to adjust this out with the rear spring bolts, without success.
Others, like myself, were able to level the car with a set of lowering bolts; dropping the right side down to the same level as the left.
Had the same symptom on my '91.
Adjusted the REAR spring bolts to compensate.
Chassis works like a big "X" whichever corner you want to adjust, go to the oposite diagonal corner.
In my case it was the LEFT FRONT that was low (same as everybody else's).
I went to the RIGHT REAR and lowered that corner.
Car sits level now.
THis is not unusual BTW. Seems a LOT of them are like this... but I've had folks FLAME me for stating it.
...THis is not unusual BTW. Seems a LOT of them are like this... but I've had folks FLAME me for stating it.
Not unusual at all. It seems that they all do this after a while to some extent or another. Mine was off by about 1/2" from side to side and it only had 23k miles at the time.
