1993 Reverse Light Problems
Old Feb 2, 2006 | 10:18 AM
bjam2's Avatar
bjam2
4th Gear
Default 1993 Reverse Light Problems
I have recently purchased a 93 Corvette and the reverse lights do not work. The bulbs and fuse are both fine. How do I get to the switch or relay that activates these? Or has anyone else had this problem that could give me some advice?
Old Feb 2, 2006 | 10:27 AM
94muscle's Avatar
94muscle
Default i hear yah
IM trying to figure this out too. All i know is GM charges 75 to diagnose the problem and close to 300 to fix it. Im sure its easy to fix though. Ill reveiw "the" chilton tonight.
GKK's Avatar
GKK
There is a switch that is screwed in on one side of the transmission. Just disconnect the wire, remove the switch and install the new switch.
Old Feb 2, 2006 | 10:55 AM
sonomacrew01's Avatar
sonomacrew01
had the same problem with my 93..
Old Feb 2, 2006 | 01:49 PM
Impala Balko's Avatar
Impala Balko
prolly the switch i had the same problem with mine...
Old Feb 2, 2006 | 02:13 PM
Phantom90's Avatar
Phantom90
What is the switch called? Color? Left side or right?
Old Feb 2, 2006 | 02:23 PM
Pete K's Avatar
Pete K
Is it a stick or auto? Your post and profile contain no useful info. Fill out your profile. Help us, help you.
Old Feb 2, 2006 | 03:34 PM
SJW's Avatar
SJW
Run a quick continuity test on the switch. If it doesn't close when the car is shifted into reverse, you'll know the switch is faulty. If the switch closes, but the lights still don't come on, look elsewhere for the problem.
Be well,
SJW
Old Feb 3, 2006 | 10:27 AM
GKK's Avatar
GKK
It's called a "backup light switch" or "reverse light switch". On my "91" 5 speed Camaro, it was mounted on the driver side of the transmission in open sight and its about the diameter of a quarter.
It's probably mounted in a similar location on the Corvette 6 speed.
To 1993 Reverse Light Problems
