Vats Security System 88 Vette Help
Old Feb 8, 2006 | 10:37 PM
blown87's Avatar
blown87
GA Events Coordinator
Originally Posted by corvetteronw
Note: you have to remove the upper dash pad and the breadbox to get to it.
Good luck!
That breadbox removal sure is fun.
Old Feb 9, 2006 | 12:14 AM
VQT88Vette's Avatar
VQT88Vette
corvetteronw,
Is the VATS module from Vette2Vette new or used? GM dealer quote me almost $300 also.
I am following these thread about the VATS to figure out my own problem with my POS.
Old Feb 9, 2006 | 09:09 AM
brookman's Avatar
brookman
I blamed all my problems on my VATS and had it programmed out.
My problem didn't go away.
Guess what - the problem was the stupid starter interrupt relay behind the info center.
Old Feb 9, 2006 | 10:39 AM
LESLIE SMITH's Avatar
LESLIE SMITH
4th Gear
Default follow up vats
Good morning! Im still not getting any power to the purple wire going to the starter but I am follwing the diognostic chart that ( Agent 86 ) provided. on page 8a-133-4 Im running the Resistance chart I got down to H lt green wire stuck keys in driverside door in lock I got infinity in unlock 5.1??? I guess im going to be pulling driverside door now. My guess is that switch may be shorted out telling computer somebodys stealing it. Im still working at it Thanks for everybodys help Ill keep you posted after I tare into the door.
