headers
Old Feb 5, 2006 | 05:01 PM
bacardioil's Avatar
bacardioil
Default headers
hi guys
i just ordered about 2 weeks ago EMs racing headers 1" 7/8" in the black ceramic coating.
any one using them and what do you think of them. Merle said they are the best headers they make bar none. iam running a s/c ed 383, 4l80e trans, blower works water/akie system. this engine and trans are being installed this week sometime.
regards
Old Feb 5, 2006 | 05:42 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Are they stepped or straight 1 7/8"? Either way they ought to be kick-*** for your radical engine. I'll be looking forward to see how it works out for you. EM makes a very good product. What are you currently running for headers?
Old Feb 5, 2006 | 06:11 PM
bacardioil's Avatar
bacardioil
chris
the engine in the car is a stock lt1 with shorties and gregs complete water alki system and gregs tune. greg used my car as a proto for his 8 rib belt system. car dyno'ed at 404rwhp and 403 rwtq. at 13 psi. greg and i were just waiting for the piston to blow but it still stays together. the new engine has the best of everything in it. all bearing, rod, mains and cam bearing are all tefflon coated. pistons are custom made with cermic coated tops and tefflon sides. looking to make some power with the new engine and the trans is raptures 4l80e trans and their computer to take it. merle and i talked about the step up and merle said not to go with them.
Old Feb 5, 2006 | 06:25 PM
Zix's Avatar
Zix
You're really going to like those headers!! Definitly post up some dyno numbers, I'm still waiting to put a set on my car!
Old Feb 5, 2006 | 08:14 PM
Corvette Kid
Originally Posted by bacardioil
chris
the engine in the car is a stock lt1 with shorties and gregs complete water alki system and gregs tune. greg used my car as a proto for his 8 rib belt system. car dyno'ed at 404rwhp and 403 rwtq. at 13 psi. greg and i were just waiting for the piston to blow but it still stays together. the new engine has the best of everything in it. all bearing, rod, mains and cam bearing are all tefflon coated. pistons are custom made with cermic coated tops and tefflon sides. looking to make some power with the new engine and the trans is raptures 4l80e trans and their computer to take it. merle and i talked about the step up and merle said the not to go with them.
To headers
