speeometer calibration
Old Feb 6, 2006 | 09:49 PM
qr449's Avatar
qr449
1st Gear
Default speeometer calibration
I just purchased a 1992 vette with a 6 sp trans. The previous owner had changed the rear axel ratio and now the speedo is way off. Any suggestion to correcting or recalibrating it. thanks
Old Feb 6, 2006 | 09:59 PM
MTVette's Avatar
MTVette
I installed an Abbott electronic ratio adaptor. See http://www.abbott-tach.com/era.htm. IT's a little black box that goes between the tranny and the computer by splicing into the speedo gear wires. Costs about $160 and can be adjusted very finely so as to make your speedometer exactly accurate.
Old Feb 7, 2006 | 01:45 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
http://www.corvetteforum.net/c4/vett...Gearshtm.shtml
or
http://www.zr1specialist.com/HAT%20W...on%20Gears.htmcalibration
Old Feb 7, 2006 | 12:03 PM
CFI-EFI's Avatar
CFI-EFI
As stated, you can buy a $150.00+ black box, or better yet, chances are a $10.00 - $20.00 stock gear will solve your problem. Step one, is to determine what gears are in the car. The surest way to fond out is to jack both rear wheels off of the ground and rotate BOTH rear wheels, precisely ONE full turn. The number of turns, and fractions, thereof, that the drive line turns, while the wheels make ONE turn, is your ratio. Then simply go to the CHART supplied by James93LT1 and pick the driven gear you need. Because your car is a manual, the drive gear and the VSS won't change.
RACE ON!!!
Old Feb 7, 2006 | 12:39 PM
tequilaboy's Avatar
tequilaboy
Another alternative: An $80 black box
http://www.dakotadigital.com/index.c...rod/prd126.htm
It works fine for me, and can easily be re-calibrated for different tires gears etc. I used a racelogic v-box to dial it in perfectly. My first attempt at calibration was very close anyway (within 1% at 100 mph).
Note: In my case I would've had to change both gears for 3.73s (15/45 from 17/42) also my transmission output shaft splines are twisted? making yoke removal very difficult.
Edit: 14/42 would also work for 3.73s, which would require only one gear change when going from 3.07s. Anyone know if a 14 tooth gear is available? Or is this a custom gear also?
Old Feb 7, 2006 | 02:58 PM
CFI-EFI's Avatar
CFI-EFI
I didn't take the time to verify the 14/42 combination, but it only allows the reuse of the cheaper, easier to replace, gear of the two. Changing the drive gear, whether to 15 or 14 teeth is the same job, and either way you have to remove the driven gear. The most you could save is the ~$10.00 for the driven gear. The 15 and 17 tooth are the only drive gears *I* am aware that are available from GM.
RACE ON!!!
To speeometer calibration
