standard v automatic?
Old Feb 7, 2006 | 04:45 PM
Derk's Avatar
Derk
Cruising
Default standard v automatic?
Which one is better for drag racing?
Old Feb 7, 2006 | 04:48 PM
vader86's Avatar
vader86
the automatic will win in drag racing at the highest power levels
at the stock levels though, the manual will likely win
Old Feb 7, 2006 | 04:49 PM
CFI-EFI's Avatar
CFI-EFI
Automatic.
RACE ON!!!
Old Feb 7, 2006 | 08:45 PM
kopbet89c4's Avatar
kopbet89c4
Its is the EXACT opposite when the car is not a V8. On a well equipped automatic RSX vs the base model standard shift, the ETs have always been 2-3 seconds slower in the 1/4th mile if the unlucky driver got the automatic.
But then again, V8s with automatics, except in Fords, have always been faster than the standard shifts in my experience, even if the manual had less drivetrain power loss. Might be the launch factor in the manual because most drivers, at least in my area, aren't good enough to launch a manual from a dig.
Old Feb 7, 2006 | 10:09 PM
psychodiagnostik's Avatar
psychodiagnostik
Regarding Corvettes, I think that autos are easier to be consistent, and for many drivers, will be faster, because it's easier to launch. Also, a tuned automatic car with a shift kit, decent gears, and a higher stall converter will usually be faster than a similiarly tuned car with a manual trans.
However, I think that banging the gears down the strip is more fun!
Old Feb 7, 2006 | 10:50 PM
Derk's Avatar
Derk
Cruising
yeah well I really suck at changing gears lol. I'm slow as hell
Old Feb 7, 2006 | 11:47 PM
Alzado77's Avatar
Alzado77
I know which one is more fun
Old Feb 8, 2006 | 12:21 AM
88BlackZ-51's Avatar
88BlackZ-51
so do i.....and its not an automatic, is it?
Old Feb 8, 2006 | 12:22 AM
90WhiteLightning's Avatar
90WhiteLightning
Instead of starting a whole new thread, I'm going to ask my similar question here. I have a 1990 Automatic. Can I "manually" shift the automatic shifter through the gears without hurting the tranny? ie - I would like to keep the RPMs up and not have the transmission shift so fast into a higher gear. I know with a 5.0 Mustang with an automatic, you can start out in low gear (D1)...move the shifter to D2..and as soon as the tranny shifts, move the shifter BACK to D1 and the transmission will "stay" in 2nd gear until I move the shifter back to D2. ....if you know what I mean......I have not tried any of this with the vette yet....I didn't want to hurt anything. Any info would be great. Thanks.
Old Feb 8, 2006 | 08:16 AM
Pete K's Avatar
Pete K
For the most part, manual upshift does not hurt any thing. Hard, forced
downshifts can. I have seen guys break the sprag doing the forced downshifts. Rare, but it happens. Trans go makes a shift kit that allows normal (full auto) features but will allow you to hold any gear at any speed.
Old Feb 8, 2006 | 09:16 AM
rick lambert's Avatar
rick lambert
I used to be very fast shifting a stick-but in reality you just can't beat the consistency of an auto-I really enjoyed sticks and popping the clutch-but I seem to be having just as much fun with the autos now.
Old Feb 8, 2006 | 09:51 AM
silver84's Avatar
silver84
although the automatic is faster at the drag strip,
Zora would have wanted you to drive
a stick at other times
Old Feb 8, 2006 | 11:26 AM
Red Tornado's Avatar
Red Tornado
Old Feb 8, 2006 | 11:31 AM
Pete K's Avatar
Pete K
Originally Posted by Hot Rod 90
In defense of the origional poster, his question is quite specific. Little doubt as to what is better in a drag race. Since drag racing on the sportsman level is bracket racing, there is little arguement that the auto is more consistant, therefore resulting in better odds of winning. Hopefully this does not turn into the monthy "stick vs auto" thread.
Old Feb 8, 2006 | 11:33 AM
Red Tornado
Old Feb 8, 2006 | 11:35 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Autos are easier to get consistently quick times at the drag strip.
Larry
code5coupe
Old Feb 8, 2006 | 01:21 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Ding ding...we have a winner..Pete is correct...
Old Feb 8, 2006 | 01:26 PM
Fuzzy Dice's Avatar
Fuzzy Dice
You can but it won't help much...no one can shift manually faster or more consistently than the computer...if your car is shifting early or at too low an rpm, address that issue separately, by adjusting the shift points...
Old Feb 8, 2006 | 01:42 PM
GeosFun's Avatar
GeosFun
I agree. A significant detail is the respective 60' times between stick and auto. An auto will win every time, particularly if a higher stall converter is in and sticky tires . But sticks tend to mile-an-hour a bit better (but not enough to catch the auto)
To standard v automatic?
