carbing my 91.....?
Old Feb 8, 2006 | 12:19 PM
ar91c4's Avatar
ar91c4
Default carbing my 91.....?
Ok I have decided to stick a holly proform and a weiand stealth intake on my 91 with a 383..Anyone have any ideas what I should look out for? I will be starting to do this saturday morning so any input would be great.
TIA.....AL
Old Feb 8, 2006 | 11:47 PM
rodj's Avatar
rodj
Where to cut the hole in the hood!
Read
http://forums.corvetteforum.com/show...93&forum_id=48
Old Feb 9, 2006 | 04:34 AM
steve1ph2's Avatar
steve1ph2
Read
rodj now now thats not necessarily necessary. although i know what post your thinking of. im still alittle taken aback as well. best advice is to search around the forum. there`s plenty of info for your project. im doing it now but only half way thru so i dont know enuf to help.
Old Feb 9, 2006 | 11:53 AM
tsiawd1028's Avatar
tsiawd1028
if you chose the right manifold and aircleaner, you will hhave clearance for the hood. the manifold i am using is the weiand xlerator, imca version. I am also using a summit drop base air cleaner
Old Feb 9, 2006 | 12:33 PM
ar91c4's Avatar
ar91c4
i was told the stealth by weiand is perfect.?
Old Feb 9, 2006 | 12:58 PM
tsiawd1028's Avatar
tsiawd1028
yes thats one will fit too
Old Feb 9, 2006 | 01:14 PM
dock351's Avatar
dock351
St. Jude Donor '06
There have been some recent posts on this topic, so check those out. Basically, it seems possible; i considered doing it, but changed my mind...carb, those manifolds already mentioned, drop down air cleaner, if you have AT, kick down linkage, lock up; fuel pump issues (some say you can use the in take pump with a regulator to step down the pressure, others say its best to just use a reg. carbed fuel pump). Distributor is the other thing to look into.
Old Feb 9, 2006 | 01:39 PM
AZC4Guy's Avatar
AZC4Guy
There's several recent threads out there. I recently carbed mine and there's really only a few problems you'll run into. Ask redc4corvette though, he seems to think he knows everything.
Old Feb 9, 2006 | 05:13 PM
ar91c4's Avatar
ar91c4
I believe I have eveything but the fuel lines, and we will make them out of braided line and fittings to fit properly. I got a 3 port return style malory regulator for the fuel issue and I got a vacume advance distributor from malory also.the biggest quetion I have is what is eveyone doing with their wiring harrness? Also what about the coolant sensor in the fron t of the tpi intake?And what do you guys think about the proform 750 carb on a 383? It does not have any type of choke or even a choke tower. I imagine this will make it a pain to warm the car up on cold mornings.anyway except for those few questions i think I have it all mapped out and hopefully I can get it on the car and running by saturday night.
thanks again guys!
Old Feb 9, 2006 | 05:17 PM
AZC4Guy's Avatar
AZC4Guy
I have a 750 on my 383, but it's a demon
Old Feb 9, 2006 | 05:22 PM
kpforce1's Avatar
kpforce1
Well, when I converted to a carb I just left the wiring harness kind of bundled up and "hidden" because I though I would go back to EFI. The Stealth intake will work but you have to use a smaller air filter. I have the "shaved" version that came with X-Ram intakes which is shorter. I just put a carb adapter plate on it. Oh, i still got 22 or so MPG with the carb. lol
I used an MSD 6AL system, MSD adjustable timing control, and an MSD pro billet dist. with the mechanical timing springs. Make sure you get a distrubutor that doesn't require a computer to control the timing... i made a mistake like this the first time... it resulted in pink glowing headers. I also used the Mallory 3 port adjustable fuel regulator.
Old Feb 9, 2006 | 05:37 PM
ar91c4's Avatar
ar91c4
So what did you do with the wiring then? Just tuck it behind the block by the tranny?
I also have a msd 6AL that I will be using and the malory distributor I bought is the one with the led trigger system...
Old Feb 9, 2006 | 05:42 PM
tsiawd1028's Avatar
tsiawd1028
I am also using the mallory 3 port regulator with the stock fuel pump. As for ignition You can go for an elborate and high perfromance such as kpforce, or you can usie a late seventies corvette hei distributor complete for under 100. Im using the cheap jegs brand distributor with 50k coil , just put it toghether and drop it in for 89.00 bucks. your stock tack and ingition lead wire are going to plug right in, you just dont you the 5 pin esc conector.
Old Feb 9, 2006 | 05:47 PM
ar91c4's Avatar
ar91c4
I understand the wiring issues as far as what to use and what not to...I am just not quite sure where everyone has been hidding the harness. I will eventualy go back to F.I. so I dont want to eliminate it completly but on the other hand I am looking for the cleanest look possible.
Old Feb 9, 2006 | 06:58 PM
tsiawd1028's Avatar
tsiawd1028
theres plenty of room, i would tape everything up toghether tightley, most of the unused stuff can be fit behind the distributor tucked away. You wont notice it there.
Old Feb 9, 2006 | 10:38 PM
steve1ph2's Avatar
steve1ph2
when you get to the fuel regulator setup and or location check out these pics. http://photobucket.com/albums/f333/s...corvette/?sc=1 i finished mine today and did not cut up the factory lines. if you need help let me know.
To carbing my 91.....?
