Anyone seen this in the hatch window?
Old Feb 8, 2006 | 04:55 PM
southpaw3519's Avatar
southpaw3519
Default Anyone seen this in the hatch window?
In certain sunlight at some angles, there looks to be splaches or discoloration in the window represented by round fade type spots. Could this be wear and tear from the defroster?
I plan on tinting the windows but would like to figure out how to deal with this first.
92 Coupe
Old Feb 8, 2006 | 04:57 PM
Gary6595's Avatar
Gary6595
Aside from possible physical damage, it's the polarization of the glass.
Old Feb 8, 2006 | 05:00 PM
southpaw3519
Looking close, there is no damage. Straight on view it doesn't show nor does it at night unless spotlighted. If it's polarization, I guess I have to live with it or place the hatch?
Old Feb 8, 2006 | 05:18 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
You may wanna check the cost of that hatch. Last I looked, over $1200 buckeroo'ssss.........................
redrage's Avatar
redrage
Mine is the same as you are describing,and the defroster has not been used for at least eight years.I figure its normal.
Old Feb 8, 2006 | 06:11 PM
southpaw3519
Anyone tint the hatch and have this go away or get worse?
Old Feb 8, 2006 | 06:51 PM
ED HEISER's Avatar
ED HEISER
My back window tint is so dark I can barely see through it in daylight, forget it at night. The previous owner had it tinted. If there are any faint discolorations, you sure can't see them. So I can safely say it won't get worse. The upside is when a truck with brights and fog lights is behind me at night, it doesn't hurt my eyes or light up the inside of my car. It matches the outside of my acrylic targa panel too.
On previous cars I've owned I've seen these "spots" also. Someone told me is is caused in the manufacturing process from cold air jets used to cool the glass when it is bonded. This could be an "Urban Myth" though.
Maybe someone who worked at a glass factory could tell us.
Old Feb 8, 2006 | 07:26 PM
rubber duck's Avatar
rubber duck
the discoloration or spots your seeing is just what happens sometimes when glass is tempered and no it will not get worse. If you look at other cars with polarized sunglasses you will see spots all over the windows.. So see your not the only one seeing spots.
Old Feb 8, 2006 | 07:34 PM
southpaw3519
I feel better knowing it's not my eyes...
Old Feb 8, 2006 | 07:38 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
I got freaked out when I got my new shades.
Old Feb 8, 2006 | 10:17 PM
1stC3Vette's Avatar
1stC3Vette
Never noticed it on mine. Could it be the affect of acid rain?
Good luck,
Dino
Old Feb 8, 2006 | 11:28 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I thought saftey glass was laminated with plastic between 2 layers of glass.Isn't that what it is?I know in the old days back windows were not made of saftey glass that is why if you shoot them with a BB gun they will totally disintergrate and shatter unlike the front window(not that I ever did that).
Old Feb 8, 2006 | 11:36 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
No, the effects of acid rain are when people ask if the effects are from acid rain.
Old Feb 9, 2006 | 02:13 AM
jrp's Avatar
jrp
All of my cars have that appearance through my sunglasses. Everyone else's too. It's normal. The effect is much more apparent on curved rear glass - thankfully not on the sides or windshields.
Old Feb 9, 2006 | 08:19 AM
mseven's Avatar
mseven
I would agree, I think the cause is from the factory tint(non-clear glass) my yukon has the same thing. It is only noticable when the car first goes into the sun and when it first gets dark like the sunglasses that change tint for the sun
Old Feb 9, 2006 | 03:24 PM
VenkmanP's Avatar
VenkmanP
Every hatchback car I've ever driven had that.
Old Feb 9, 2006 | 05:10 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Corvette glass isn't polarized.
But polarized sunglasses will show these spots on many, many cars.
Larry
code5coupe
To Anyone seen this in the hatch window?
Old Feb 9, 2006 | 05:42 PM
SJW's Avatar
SJW
Windshields are two layers of glass laminated together with a transparent membrane of plastic sandwiched in between. This laminated glass is designed to not shatter into flying bits of glass if it's hit by a rock, etc.
The remainder of the glass is tempered, so that it will shatter into pebbles and dust, rather than long shards. The pebbles can cause lacerations, but won't impale you and cause deep wounds like long shards of broken, non-tempered glass can do.
Be well,
SJW
Old Feb 9, 2006 | 05:55 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Whatever it is, it's normal. I've noticed the effect on many cars over the years.
Old Feb 10, 2006 | 12:15 AM
jasenr's Avatar
jasenr
That's what mine looks like. I guess it's normal also.
