89 white conv. transmission slips
Old Feb 9, 2006 | 04:38 PM
89 white conv.'s Avatar
89 white conv.
Default 89 white conv. transmission slips
I have a question . I have a 89 white corvette with a 700 R trans. When it is cold the first time it shifts into overdrive it slips a little. Then every time after that it is fine. Do they still have belts that can be adjusted or do I need the whole trans. rebuilt . Thanks, Ralph
Old Feb 9, 2006 | 06:47 PM
wpsrea's Avatar
wpsrea
I would suggest a fluid change with new filter before I put any real money in it.
Old Feb 9, 2006 | 09:25 PM
gbody5's Avatar
gbody5
Can't hurt to reset the Throttle Valve cable too.
Old Feb 12, 2006 | 12:29 AM
SunCr's Avatar
SunCr
Need more info - at what temp - what speed - what gear (3 or 4)? Torque convertor lockup on the 700R4 can be erratic between 35 and 40 mph depending on load. It shouldn't be happening at all until closed loop, so monitoring that parameter might give you some clue as to where the problem lies. A fluid change won't hurt it, but probably won't cure anything either. Leave the TV cable alone - there isn't any adjustment necessary unless you're replacing the cable and if you screw it up, there will be other problems.
Old Feb 12, 2006 | 10:14 PM
C4driver99's Avatar
C4driver99
prolly just a bad filter and old fluid
Old Mar 1, 2006 | 09:41 AM
Pete K's Avatar
Pete K
I would make a post in c4 tech. You will get more info there.
To 89 white conv. transmission slips
