I've been looking at cam specs and have seen that quite a few of you use the LT4 Hot cam #24502586.
My question is have any of you run into valve spring problems? The reason I ask is that the valve springs recommended for the hot cam are#12495494 (16) or the 12361329 (1). The specs say that maximum lift is .525".
The Hot Cam with 1.6 rollers has .525" lift! I'm interested in the swap but I really don't want to swap out fatigued valve springs all the time.
Also with the cams duration of 218/228 @.050 and 112 lobe center is the stock LT4 computer able to compensate for this cam (and pass dyno emission testing)?
Thanks for your help!
I have the LT4 Hot Cam in my LT1. I replaced the springs with the house brand from Internet Racers Supply. They have a max lift of like .550 So far they seem to be doing a very good job. I think the common thought is that the LT4 computer will run alright, but not optimal with the cam while the LT1 won't run worth a crap. Correct me if I'm wrong.
I wouldn't run it with the stock programming, your WOT fuel tables will be off and your idle will be too low. I fired up my LT1 with a LPE cam and drove it down the street one time with the stock chip and it ran ok, but it was barely kicking over at idle. MAF cars should be better in general, but still have the idle and WOT issues.
The hot cam will not fatigue vavle springs. The lift specified is with 1.6 roller rockers and its not very agressive for 218 degree duration. I had a Crane cam that had 520 (1.6) lift with only 210 degree intake duration. That cam is harder on valve springs but still won't fatigue them. The LT4 computer can handle the cam but the idle probably needs to be raised a bit.
I think the MAF LT1 (94-96) computer will run fine with the hot cam as long as you raise the idle speed. My car ran fine and passed emissions with the stock LT1 programming when I had the Crane cam in it. 210/224 dur 112 LSA 520/550 lift w/ 1.6 rockers. Engine was 383 with AFR heads.
i'm running the crane dual valve springs (closed seat pressure is 120#) good to .600 lift with my hot cam.
and yeah, the hot cam is only .525 lift with a 1.6 rocker.. it's .492 with a 1.5 (stock) rocker..
my '94 LT1 (first year of MAF for LT1's) ran fine with stock programming, just bump the idle up a little with the idle set screw in the TB.. you will want to get the pcm reprogrammed tho to get max power.. i had shalin do mine (took the car out east) and he did a great job. always go for dyno tune if you can.. mail order pcm programs rarely give you what you pay for.
