Gans tank building up pressure, why?
The pressure is caused by the higher pressure of the electric fuel pump, higher pressure that is required to keep the injectors flowing. The fuel return does its thing, and the end result is a pressure build up in the tank. The stored pressure is vented, sorta, through the charcoal canister. You may have a problem with your canister, tho, if the pressure is too high.
Blowing the cap out of your hand is pressure. Check the canister...
Look in the past posts, he might have turned it into a tech tip as well. It scarred me enough that I went right out and made sure my canister wasn't falling apart. This weekend (if it doesn't rain too much) while I'm doing the brakes on the other cars I'm going to check and see if I can blow thru the lines.
[Modified by djpearn, 6:29 PM 8/9/2001]
Heres the link for the problem I had and how i fixed it.
http://www.corvetteforum.cc:88/zerothread?id=93566
I highly suggest you use compressed air starting from the tank and unhook the rubber lines under the car from the steel line and see if compressed air will pass through.(This is how I found my line was clogged.)
Then see if air will pass through the steel line under the car to the front of the engine.
Check each section of line until youre up front to where ever the vapor line is supposed to vent the gas fumes.
Not sure if youre 88 is a little different then my 86 set up as far as where the vapor lines go.
Since I replaced the canister, rubber hoses and the clogged steel line, i have NO more high pressure back there like before...gas tank doesnt heat up anymore.
After driving around for a good while then get home, it will barely even hiss when I take the cap off to check it..before the fix it was Hissing so loud and hard the gas cap wanted to fly across the street when I took it off.
Get this fixed asap...its a disaster waiting to happen.
Im glad it didnt explode on me.
