Simple L98 timing questions
Old Feb 11, 2006 | 10:18 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Simple L98 timing questions
'88 L98 w/ 6 speed conversion, otherwise totally stock. I'm wondering where's the best place to set initial timing and what to look for, for total advance. Also thinking of putting a curve kit in it. The owner just wants a little more pep. Thanks.
Old Feb 11, 2006 | 11:39 AM
Morley's Avatar
Morley
Stock TPI, 6* BTDC. A "curve kit" won't work, the spark curve is controlled by the ECM via the programming in the prom chip.
Old Feb 11, 2006 | 11:49 AM
CFI-EFI's Avatar
CFI-EFI
Unless you hook up a scanner and go for a run, you'll never be able to see what the equivalent of "total" is. I would just start making runs and adding 2° until it quits improving, and then back to the previous best. I ended up with a base of 14° BTDC that way. Most people end up with 8° to 10°.
RACE ON!!!
Old Feb 11, 2006 | 02:46 PM
Corvette Kid
Interesting. I hadn't looked under the cap yet but was assuming that all of the big distributors still had mechanical advance. So I guess when the precipitation stops here, I'll just take it out and play with it! Thanks for the tips, fellas.
Old Feb 11, 2006 | 03:00 PM
vader86's Avatar
vader86
Start at 6', but you'll end up at either 8' or 10'
Old Feb 11, 2006 | 05:09 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Run what timing the motor runs best at. Do not shoot for a specific number. You are using a stock pointer that may or may not be dead on at 0* (TDC).
Go to a track or dyno - run the car at various timings and see what produces the best numbers. I usually start out conservative and then keep adding timing till my MPH drops off at the track. Back the timing up and lock it down where it ran the best MPH. Best MPH = Most power.
Old Feb 11, 2006 | 09:13 PM
hardlight's Avatar
hardlight
I wound up at 10 deg. and got a better initial jump but then the ECM takes over and controls the timing. I guess its just a little feel good, I did something kind of thing but the ECM is the boss.
Old Feb 12, 2006 | 01:27 AM
Corvette Kid
This is what I know and what I miss about the engines I grew up with. I always tuned engines 'to themselves' and that's what I will (obviously) do in this case given what all of you have said. There is great bang for the buck in tweaking ignition timing, virtually free! Don't get me wrong, as easy as it was to play with the mechanical distributors, I love electronic engine management and don't wish to go back. I just envy you guys who can do your own tuning and I hope to join your ranks one of these days. Thanks to everyone for the input
Old Apr 25, 2006 | 04:26 PM
YoMilkMan's Avatar
YoMilkMan
Yep ECM is DADDY. I have my Spark tables in my prom set to 15* in my low RPMs and slowly decrease in the high RPMs.
Old Apr 25, 2006 | 04:52 PM
tequilaboy's Avatar
tequilaboy
The "total advance" for an 88 L98 in the high rpm/high load area is between 32 and 35.9 degrees. A couple of excerpts from the ABTR table. Spark vs rpm vs load.
Load = 192
4000 rpm 32
4400 rpm 33
4800 rpm 35.9
Load = 208
4000 rpm 28.8
4400 rpm 32.0
4800 rpm 35.9
Advancing the base a couple of degrees from 6 may help here, but will push you kind of high above 4800 rpm. (not really a problem for a stock L98)
Old Apr 25, 2006 | 05:49 PM
88421VETTE's Avatar
88421VETTE
RACE ON!!!
I'm running the same timing on my 88 Iroc L98. It has no knock But I have to run 91 octane.
Old Apr 25, 2006 | 07:31 PM
CFI-EFI's Avatar
CFI-EFI
That is iron headed like mine, isn't it? I use 85 octame gasoline, exclusively. I am sure my compression ratio is lower than yours.
RACE ON!!!
Old Apr 26, 2006 | 10:02 AM
88421VETTE's Avatar
88421VETTE
RACE ON!!!
yah it's Iron headed I think comp is 9.3 or something around that
Old Apr 26, 2006 | 10:31 AM
rick lambert's Avatar
rick lambert
I ended up at 8 on my 87, I've always believed in the -set it where it runs best. Hey Kid, I grew up with those engines too, mech and vac.
I actually liked toying with weights, springs etc.But, I too like the electronics of our engines-except when there's a problem.
To Simple L98 timing questions
