CODE QUESTION
Old Aug 9, 2001 | 12:05 PM
DADDY D's Avatar
DADDY D
Default CODE QUESTION
I have an 86 vette with a 700r4 trans. I keep getting code 36 which says "Ignition system circuit error or Transaxle shift problem-4t60e transaxle." What do I to fix this problem.
Old Aug 9, 2001 | 02:49 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: CODE QUESTION (DADDY D)
Code 36 on a Vette refers to the MAF burn off relay. You may need to replace the two relays behind the battery that control the MAF. I recently had this happen.
There is a TSB from GM on this that has a lot of info on codes 33, 34 and 36 (All MAF issues) I don't have the users site that had it, but I'm sure someone does.
Old Aug 9, 2001 | 04:29 PM
W4ZG's Avatar
W4ZG
Default Re: CODE QUESTION (two-tone86)
Had similar problem... :yesnod: ..without a long story :sleep:...it cost me a new MAS... :eek:...and both relays.. :( ...but the good
news :bigears....problem solved... :cheers:
Old Aug 9, 2001 | 05:05 PM
Springer's LT4
Default Re: CODE QUESTION (W4ZG)
Hey W4ZG!! I know that that bridge in your picture! Thats Carillon.. looking at it from my from my office as I type!
Old Aug 9, 2001 | 06:18 PM
W4ZG's Avatar
W4ZG
Good lord.. :eek: ...you are the second person who recognized my secret photo location.. :jester ... Wife works at R/J and we haved lived in Feather Sound since 1979... :seeya
Old Aug 9, 2001 | 11:30 PM
DADDY D's Avatar
DADDY D
The two relays behind the battery what are they called.
Old Aug 10, 2001 | 09:28 AM
O'Shark's Avatar
O'Shark
Hey Dennis, it's good to see another ham on the forum :D BTW, I need your grid on 6&2M :D:D
Sorry for the off-topic there but yes, new relays fixed my problem too.
Old Aug 10, 2001 | 12:03 PM
W4ZG's Avatar
W4ZG
The two relays in question are located behind the battery...on the fire wall...the outboard relay is the Mass Air Flow Sensor Relay and the inboard relay is the Mass Air Flow Sensor Burn Off Relay... :yesnod: ...It is best to replace both at the same time :yesnod: ...on my 89...both relays had the same part #.. :yesnod: ...p/n 14089936...cost from dealer was $16.00 apiece...I'm sure you can beat that price.. ...the MAS sensor itself , again from the dealer....was over.....I hate to say...$400.00 ... :cry...that was the last time I've been to the dealer :D
To CODE QUESTION
