Frisbe
Old Feb 11, 2006 | 01:19 PM
Larry64's Avatar
Larry64
Default Frisbe
I'm new and just found out about the frisbe on my 1990 L98. Can someone give me the skinny on its removal. Do I need to remove the pully and belt, is it safe, and will I feel it on the throttle?
Old Feb 11, 2006 | 01:25 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Removal of pully and belt aren't needed. Get four small lock washers to put on the bolts to replace the thickness of the frisbee. On earlier models this wasn't needed but on my 90 the bolts bottomed out before the pully was tight. Do this and you'll be ok.
Old Feb 11, 2006 | 01:43 PM
thomastl's Avatar
thomastl
You won't notice any difference in the throttle. You might see a couple hp on a dyno. It si there to tampen the shock when the A/C compressor kicks in.
I had to reinstall mine as the compressor made an awful noise when removed. Mine is an 88 w/ the A/C converted to 134A.
Old Feb 11, 2006 | 03:07 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
no no no..........change it out with a high performance chrome one. You won't regret it...........
Old Feb 11, 2006 | 03:10 PM
cdnguyred88's Avatar
cdnguyred88
Removed mine 4 or 5 years ago and no problems at all.
Old Feb 11, 2006 | 09:19 PM
hardlight's Avatar
hardlight
AND, its gotta go if you put an R-DRacing Camber Brace between the top A frames. The Camber Brace is one of the better things you can do to this sportscar.
Old Feb 11, 2006 | 09:47 PM
Fork501's Avatar
Fork501
Make sure you have a long breaker bar with you. You'll need it there to hold the frisbee in place, while you try to get the bolts out. If you're using an impact wrench, you won't have that issue.
I had an issue when I took mine off that it was making a horrible sound. All I had to do was tighten it even more (which, too tight can cause damage, so be careful..) and it was fine.
Best of luck!
~Derek
Old Apr 23, 2006 | 01:33 PM
Spike34's Avatar
Spike34
Default Not to restart an old thread, but ...
Not to restart an old thread, but ...from the information here ( I have a 91 and would like to take off the Frisbee as well), I would not have to take off the pulley or the belt ??? So, just the four bolts, add some washers and nothing else ??? Sorry, to take the threrad, but it is on the same topic and I am somewhat tentative with the engine aspects of the Vette (regarding whacking it with a hammer )
Old Apr 23, 2006 | 04:04 PM
skateparkdave
If you look at it you'll see that the frisbee is actually mounted to the waterpump *through* the belt pully. No belt/pully removal is needed. Just remove the four bolts. Remove the frisbee. Place four lock washers on the four bolts (one each) to replace the thickness of the frisbee mounts and reinstall bolts. This is to ensure that the bolts dont bottom out before the pully is secure. It's easy as pie.
Old Apr 23, 2006 | 05:25 PM
L98Corvette's Avatar
L98Corvette
Dave, i was out trying this the other night, i couldnt get the firsbee to stay in place while trying to break the bolts loose, it just wanted to turn. How does one hold it in place so it doesnt turn? I have no air tools, just regular tools.
Old Apr 23, 2006 | 10:36 PM
skateparkdave
I think Fork501 has your answer.
~Derek
I actually didn't need one but it sounds like you might. I just used a long solid screwdriver arranged just so between the bolts. Held it with one hand and wrenched with the other.
Old Apr 24, 2006 | 10:44 AM
Spike34's Avatar
Spike34
Default Remote possiblity ??
Is there a remote possiblity anyonew knows the size fo the lock washers needed before I start the removal.
Aslo, Thnaks to all of you for all the help, this looks to be something I can actually do
Old Apr 24, 2006 | 09:03 PM
GKK's Avatar
GKK
I didn't have to use any lock washers when I removed the frisbee from my "89" and "91" Vette's.
I just removed the four bolts, removed the frisbee and reinstalled the four bolts. The bolts had plenty of clearance and the pulley rotated fine.
Old Apr 25, 2006 | 10:55 AM
Spike34's Avatar
Spike34
Default Thanks Again for the info.
Thanks Again for the info. I will be working on the Frisbee removal this weekend.
Old Apr 25, 2006 | 11:16 AM
neat's Avatar
neat
91 here. I didn't need washers, but I do have a slight vibration at 2300 or so when the AC is on that wasn't there prior to the frisbee removal.
Old Apr 25, 2006 | 12:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I used the tension of the serp on the pulley along with a large screw driver across the front of the pulley to hold the pulley while I broke the bolts loose.
Then I removed tension on the serp (don't what the pulley to go flying when I remove the bolts... ) and removed the nuts & frisbee.
My '88 had studs holding the pulley & frisbee, which I replaced with bolts & lock washers.
Time slips show it releases about 10chp, i.e. 1mph gain in trap speed.
To Frisbe
