Rear end math
Old Feb 11, 2006 | 08:35 PM
old motorhead's Avatar
old motorhead
Default Rear end math
Or maybe a$$ math? If my rear end ratio is 3.07 and I'm thinking of going to a 3.73, could I figure the rpm I'd be running with the new rear with a little math? Ie 3.73 / 3.07 X old engine rpm (at any particular speed) equal rpm with the new rear at that same speed? If I'm doing 60 mph at 2000rpm, would that rear end swap yield 2430 rpm at 60mph?
Old Feb 11, 2006 | 08:57 PM
aboatguy's Avatar
aboatguy
Check this link out LINK
If you have an A4 use the LT1 Camaro with A4 (700r4s 4l60E)
Mike
Old Feb 11, 2006 | 09:11 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Unless you plan to never use this car on the highway and don't care about mileage, I'd consider something in the 3.3 or 3.4 range maximum and go with a little more converter instead of a radical gear. If you're looking for more punch, I'd go with more converter first before even thinking about a gear change. The 3.07 is not a bad all purpose gear for the A4 cars. A 2400 RPM stall would wake up an A4 big time.
Old Feb 12, 2006 | 11:07 AM
YellowFvr1's Avatar
YellowFvr1
Default stupid question
I've been meaning to ask this of someone lately....can anyone explain to me how a TQ converter works/what it does, and how the 2400, 2600, 2800 different stalls would make an A4 car faster? And would it be faster just off the line, or from most any speed?
p.s. I got kindof some funny #'s from that calc, using the f-body a4, with 315/35x18 tires and a 3.45 rear gear. I put the redline at 7000, and it gives me first gear topping out at 53, second topping out at 99, third at 161....and fourth at 231?!!
Old Feb 12, 2006 | 11:24 AM
CFI-EFI's Avatar
CFI-EFI
YES!
RACE ON!!!
Old Feb 12, 2006 | 12:13 PM
YellowFvr1's Avatar
YellowFvr1
ttt that calc gave me weird #'s for a stock lt1 a4, too......3.07 gears, 6k redline, stock 285 40 17 tires.....says 3rd gear redline is 150+.......not so
Old Feb 12, 2006 | 02:00 PM
YellowFvr1's Avatar
YellowFvr1
anybody?
I'm trying to figure out what an a4 would do with 315 35 18 tires in back, 7100 rpm redline. 3.45 gears....?
Old Feb 12, 2006 | 03:43 PM
YellowFvr1's Avatar
YellowFvr1
lonely.....I'm so lonely....
Old Feb 12, 2006 | 04:06 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by YellowFvr1
anybody?
Measure the tire and then do the grade school arithmetic.
RACE ON!!!
Old Feb 12, 2006 | 04:16 PM
SupaVette's Avatar
SupaVette
I'm pretty sure it was ski_down_it (or was it Nathan?) who's normally in the scan and tune section who has put together a very usefull excel spredsheet for these calculations. All you do is put in the various options like wheel size and tranny and it works it all out for you. If you don't find him, pm me your email and i'll send it on to you
Old Feb 12, 2006 | 04:23 PM
YellowFvr1's Avatar
YellowFvr1
Old Feb 12, 2006 | 04:31 PM
SupaVette's Avatar
SupaVette
I got your pm, and i've sent mail
Old Feb 12, 2006 | 05:46 PM
YellowFvr1's Avatar
YellowFvr1
so it looks like that calc wasn't too off......that excel sheet is priceless, though.
a4, 315 35zr18 tires, 3.45 gears, 7,000 rpm......
top of 1st: 53, 2nd: 99, 3rd: 161 4th:....????
If I get my 396 going and spin it to 7100 like I'd like, that'd add a mph or so to each gear I like the shift points, although I wish first would be about 57, and that 4th had some sort of closed/shorter ratio so it would pull a bit harder
Old Feb 12, 2006 | 09:56 PM
C4driver99's Avatar
C4driver99
Does changinig your gears on the rearend give you more horsepower? or what exactly is the purpose of it.
To Rear end math
