Maf
Old Feb 12, 2006 | 06:50 PM
Aardwolf's Avatar
Aardwolf
Default Maf
Here is a picture of my MAF, I always wondered if it should have a bottem wire? It's the same MAF that came with the car and it didn't have a bottem wire when I descreened it and removed the heat sinks. It kinda looks like there should be a four wire, so I thought I'd ask.
http://forums.corvetteforum.com/phot...sort/1/cat/500
That link work to put the picture in this message? If it didn't click my photos to the left under my name.
Old Feb 12, 2006 | 07:21 PM
Aardwolf's Avatar
Aardwolf
How to get the picture to appear here in the message body?
Old Feb 12, 2006 | 07:25 PM
MrNuke's Avatar
MrNuke
Nope, it is fine.. That's how they ALL are..
Only 3 wires..
Old Feb 12, 2006 | 07:53 PM
Aardwolf's Avatar
Aardwolf
Ok thanks, I always wondered. Thought I'd take a pic and ask since I've got it taken apart.
Old Feb 12, 2006 | 09:43 PM
C4driver99's Avatar
C4driver99
you can descreen your maf? Did it help you out any? Not to hijack the thread or anything.
Old Feb 13, 2006 | 01:41 AM
MrRenoman's Avatar
MrRenoman
Looks like your flipp'n somebody off
Old Feb 13, 2006 | 02:07 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
That's all there is to it. A single thin wire (hot wire) connecting between two leads.
Old Feb 13, 2006 | 11:37 AM
Aardwolf's Avatar
Aardwolf
"you can descreen your maf? Did it help you out any? Not to hijack the thread or anything"
It will flow more air. It's one of the "free mods" and I like to work on my car so...
I used a can opener to take the screens off and a hand saw to remove the heat sinks. Also I used a sharp knife to remove a ridge of plastic sticking up in the middle of the tube. It was like a casting ridge. Then I put a little diaelectric grease around the o-ring so it would seal better.
"Looks like your flipp'n somebody off"
Yeah there's a couple I wanted to!
I still can't get the photo to post right.
Old Feb 13, 2006 | 11:50 AM
stubbs's Avatar
stubbs
Put this on the front of the pic address [IMG] and then put this after it [/IMG]
that will show the pic in the post.
Old Feb 13, 2006 | 02:30 PM
Aardwolf's Avatar
Aardwolf
[IMG] http://forums.corvetteforum.com/phot...sort/1/cat/500 [/IMG]
Old Feb 13, 2006 | 02:34 PM
stubbs's Avatar
stubbs
I didn't realize the pic wasn't hosted.
Go here to host it, then enclose the webaddress withing the [IMG] tags
http://www.porteighty.biz/uploader.php
Its free
Old Feb 13, 2006 | 03:21 PM
Aardwolf's Avatar
Aardwolf
Ok, thank you!
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
To Maf
