select ride shocks
Old Feb 12, 2006 | 09:41 PM
redvette6speed's Avatar
redvette6speed
5th Gear
Default select ride shocks
Can select ride shocks be changed to regular without getting an error code?
Old Feb 12, 2006 | 10:03 PM
bogus's Avatar
bogus
should be able to. Just tie the modules off and be done with it.
Old Feb 13, 2006 | 12:12 AM
JeffM1243's Avatar
JeffM1243
To avoid the error codes and lights just unplug the controller....
Old Feb 13, 2006 | 01:09 AM
aminnich's Avatar
aminnich
Where is it located?
Old Feb 13, 2006 | 07:07 AM
JeffM1243's Avatar
JeffM1243
Should be located under one of the the cargo area storage bins....You have to lift the bin out to access it, the controller is mounted on the side wall, next to the ABS pump...On my 1990 it is under the drivers side bin, but I think on later years it was moved to the pass. side...
Old Feb 13, 2006 | 08:43 AM
hardlight's Avatar
hardlight
Did you get the error code? It might be better to get all the facts before you make a decision to disable the system entirely.
To select ride shocks
