stroker
Old Feb 13, 2006 | 02:40 AM
sweets's Avatar
sweets
Default stroker
im almost ready to build a new motor for my 89 vette. has any one put a 383 stroker in there c4? i was wondering what to look out for as far as fit and application , running on pump gas ect.
Old Feb 13, 2006 | 02:44 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
You will have to recalabrate your chip and you might talk to these guy's first.
www.strokermotor.com
Old Feb 13, 2006 | 02:57 AM
sweets's Avatar
sweets
thanks, ill call them and see what they will tell me. i dont want to have issues that keep the car sitting as i figure them out. i want to know what i need to before this project starts.
Old Feb 13, 2006 | 03:09 AM
REDC4CORVETTE
Mo on the form here had them build him a motor .So far He seems to be happy with it.I have my LTX block at their shop now being punched out and splade caps put on it.
Old Feb 14, 2006 | 09:13 PM
rugby!'s Avatar
rugby!
my 383 runs on 92 octane at about 10.4 to 1 compr. getting the chip right will be your biggest problem. i have a chip from fastchip and pcmforless and i am trying to get the one from pcmforless more hp i just have to get it on the dyno. i love the 383 it makes it a totally different car
Old Feb 14, 2006 | 09:18 PM
Pete K's Avatar
Pete K
I have been running a 383 for about 10 years. First one had about 10.4 to 1 compression, second one has 10.7 to 1 compression. Because it is maf, it has tolerated the stock programming quite well. 383 is such a common upgrade because it works very well. Best thing I have done. Build it and drive it hard.
Old Feb 14, 2006 | 10:27 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
If you have not done so already, definitely familiarize yourself with the basics of scanning and data logging, and what all the values mean. Learn all about the electronics of your fuel injection system, sensor feedback, the ECM, etc. If I could do it all over again, I would have definitely learned ALL about these items on my stock engine BEFORE installing my 383.
Depending on the extent of your build, you will likely need a custom tune. If you do not plan on tuning yourself, I strongly recommend talking to your tuner before you put your combination together. Some combinations work much better than others, and a good tuner will get you going in the right direction.
To stroker
