383, HSR Intake, cc306 cam, and Brodix or Dart heads?
Location: Edwardsville, Illinois 88 stroked s10, 92 stock 6spd
Which heads would be better- more or less out of the box (going to port match with the intake and smooth casting flaws)- for my above combo? Thinking of 200cc, 64cc- Dart Pro1's, Brodix Track1's, or Brodix RR200's.
1 Post
I don't have much experience with Dart aluminum heads, but have quite a bit of experience with their iron heads on circle track motors. Excellent heads and their aluminum castings are designed pretty much the same. However, I have a lot of experience with Brodix, know the owners of the company and at least in the past 8 years they've been hard to beat. A box stock set of T1's with the combination you're talking about should make 525-550 hp with the right cam and tune. I just got the opportunity to play with a set of the Race Rite 200's on the flow bench and was impressed with their mid-lift numbers.
-Jeb
the guy that does all of the port work for racers in my area seems to push darts (he doesn't sell them- he just sells his labor for machine work). i have never heard a bad thing about brodix heads or iron dart heads- i just don't know much about their aluminum heads.
looks like it's between the dart's and the brodix rr200's now. the track1's are a 1206 gasket- and in order to get the hsr to work with a 1206 gasket- you have to add material to the top of the ports- i don't care to screw around with that.
i am thinking the pro1's are the way to go- at least over the brodix race rites. the pro1's have better flow than the race rites- all the way till abouy 550 lift. i would think that the range under the highest point on the valve lift would be more important than what they flow at the peak lift of the valve.
Originally Posted by AZC4Guy
I have Dart Pro1's on my N/A 383... very pleased with them
call harold at portpros.com he did me up a set of lt4 ported heads. they flow 287 int. 190 exh. at .550 lift. with a set 1-7/8 headers you could pick up 20 or 30 more cfm's on the exh. side.
