Valve covers
Old Feb 13, 2006 | 05:05 PM
C4driver99's Avatar
C4driver99
Default Valve covers
Has anyone seen Eddlebrocks chrome valve covers at advanced/autozone for 40$. Why are they so cheap. Also is it hard to replace valve covers. Mine are peeling really bad. Thx.
Old Feb 13, 2006 | 08:16 PM
tbone42's Avatar
tbone42
i have not seen them but would check them out a bit further. I just replace mine with the elite series from edelbrock and man they look great.I got them from ecklers for for 180. As far as being hard to do not bad at all it was fun to play with my car an this winter when i can't drive it
Old Feb 13, 2006 | 08:22 PM
stubbs's Avatar
stubbs
I got these for 115 bucks from Summit
C4driver99's Avatar
C4driver99
Its always fun to play with a vette. Just waiting to unleash it on the road again
Old Feb 13, 2006 | 08:23 PM
C4driver99's Avatar
C4driver99
BTW very attractive valve covers. Thats what these looked lilke but just all chrome. Maybe a discontinued sale?
Old Feb 13, 2006 | 08:26 PM
stubbs's Avatar
stubbs
Maybe I guess, I was actually shocked when I found these. Up until then I had only seen the chrome smoothies and "thats not my bag", to retro for me.
Old Feb 13, 2006 | 08:33 PM
C4driver99's Avatar
C4driver99
Yea. Yours look incrediable. If you can would you post a pic of it installed. Just so i could get a idea of what it looks like. If not no biggie. Thanks.
Old Feb 13, 2006 | 09:05 PM
stubbs's Avatar
stubbs
I will when it's in, here is where I'm at
Old Feb 13, 2006 | 09:57 PM
C4driver99's Avatar
C4driver99
Wow. That looks like a tough task. So what are you doing? engine upgrade? Modifacations?
Old Feb 13, 2006 | 10:04 PM
stubbs's Avatar
stubbs
383, 4 bolt block, SPR Forged Pistons, Forged Scat H Beam rods, Scat cast crank, Plasma Moly Rings and everything you see in the sig, plus a Centerforce clutch, I can't wait till its done.
Old Feb 13, 2006 | 10:13 PM
C4driver99's Avatar
C4driver99
If you dont mind me asking how much hp you got from all that. Im new so i dont know that much
Old Feb 13, 2006 | 10:16 PM
stubbs's Avatar
stubbs
Tests of similar motors both in displacement and CR have made 440-450HP and 550-575 FtLbs of torque with intakes like mine with similar cams. Thats my goal.
Old Feb 14, 2006 | 02:55 PM
parafrog's Avatar
parafrog
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
they're cheap cause they're cheap metal chromed--not stiff aluminum that will give you a more consistent seal. leaking valve covers can pull oil down through the guides into the combustion chamber.
i found out my old valve cover seals were leaking by looking at my plugs using the reading guide on this site:
http://www.4secondsflat.com/Spark_plug_reading.html
frog.
Old Feb 14, 2006 | 07:14 PM
C4driver99's Avatar
C4driver99
Thx froggy.
Old Feb 15, 2006 | 03:19 AM
smacko's Avatar
smacko
Looks good - I got mine for AU$15 a PAIR at a hotrod show - cheap and nasty but surprisingly they dont leak with felpro seals.
You could always paint or detail them in between the fins if you wanted.
Here's mine (Scroll right down and you'll see what I did with detailing)
http://www.australiancorvettes.com/p...wtopic.php?t=3
Old Feb 15, 2006 | 04:51 AM
USAsOnlyWay's Avatar
USAsOnlyWay
frog.
Whoa Whoa Whoa!!!!
Leaking valve stem seals can cause oil to drip down into the combustion chamber.
Leaking valve cover "seals" or actually the rectangular gasket can cause oil to leak onto the exterior of the head and onto exhaust pipes.
The shape/form/gasket of the valve cover has nothing to do with spark plugs. However, he is right that cheap and flimsy vc's MAY not seal right and leak oil. Just not into the combustion chamber of the head!
Old Feb 15, 2006 | 05:24 AM
parafrog's Avatar
parafrog
Originally Posted by USAsOnlyWay
Whoa Whoa Whoa!!!!
Leaking valve stem seals can cause oil to< "(drip down)"-misquote see above> into the combustion chamber.
actually leaky bits can do many things, especially if a cylinder is sucking air--especially if your rings, valves, seals or guides, or all of them are less than spec or (dependant on the cycle) blowing air through the covers--or worse-the pump leaks during both cycles.
in my opinion, sucking air and oil into a cylinder is worse than the compressed cylinder pressure blowing oil through the valve covers onto the headers. an internal combustion engine is basically an air pump powered by the introduction of an explosive vapor. its job is sucking gasoline vapor through valves into the cylinders, compressing it, igniting said vapor, holding it for maximum power and expelling the combustion gases through valves. repetitive explosions drive the crankshaft in a constant direction which is transfered to the drivetrain.
the auto air pump operates best when air induction and expulsion are fully controlled by the camshaft. the engine mechanical and computer systems are designed to work best under ideal and predictable conditions. ergo: don't want no leaks. leaks are bad.
physics 101
i can remember when i was young and had a hard head.
if you don't believe me that air leaks on a compressed system make a difference, look at the website i listed above. it is the most comprehensive site i have ever seen on reading plugs. look at it, and you will see why i was so impressed and enlightened. at least, i hope you will.
froggy.
To Valve covers
Old Feb 15, 2006 | 08:20 AM
FD2BLK's Avatar
FD2BLK
physics 101
froggy.
Ummm, Long before there where PCV systems they had breathers (A big hole in the top of the VC with an air cleaner). Many people still use the breather system and with no problems of leaky valve seals. The PCV systems do a lot of good for the motor but that is because it provides a positive suction for the crank case ventilation system. Trust me on this one if you have a poorly sealed VC it will spew oil all over the motor long before you have any sort of combustion problems.
If this is the point in the article you are refering to it is probably refering to a ceter mount plug. In that case a leaky valve cover could fill the hol;e with oil and then leak oil into the CC. For a SBC this is not going to be a problem because you will be dumping oil onto the exhaust and fire will be of bigger concern
"leaking valve covers allowing oil to seep through the plug threads, whatever it needs to be fixed."
Old Feb 15, 2006 | 11:21 AM
rick lambert's Avatar
rick lambert
Hey Stubbs, what's that YELLOW thing in the back ground-you're not
copying AGENT86 are you Yeah those cheap valve covers are cheap because they're low grade and it won't be long-I'd rather paint mine.
Old Feb 15, 2006 | 12:05 PM
stubbs's Avatar
stubbs
The ARP bolts or the garbage can? The garbage can is at my mechanics shop, its not mine. Does AGENT86 have one or something?
