Gut the Cat?
1) Is there a writeup somewhere, so that I don't do it wrong and end up having to buy a brand new one?
2) Would this cause the car to fail an emissions test? I'm moving up to GA in a year or 2 and I would much prefer NOT to have to go through and replace parts, because I was stupid the first time around.
Thanx in advance!
~Derek
IMO not worth the headache for the 3, maybe 5hp increase, youll never feel it.
I've been thinking about getting a Catco High-Flow. ($105 from racepages.com)
Would that fit stock? Also, would I expect any sort of performance gain from it?
~Derek
You need Longtube headers to see a major difference. Might be a problem if you need to pass emissions eventually.
I am not a fan of gutting cats... if for only one reason: if we, as hobbiest and enthusiasts continue to act like its 1966, we will loose everything. the EPA will mandate that every state follow CARB like enforcement. In short, we will be ****ed.
The other side of the equation, states like CA and NY are initializing road side test systems. These will use infared sensors to tag gross polluters. As far as I know, if your car stinks, it will get a notice, no matter where it is tagged. You may not get a fine, but you could get a nasty gram. But don't be surprised if you get a fine. These will start to popup in major urban areas over the next 20 years, I suspect.
The L98 has a most restrictive exhaust system. The best way to liberate power is to remove the entire exhaust system and add a true dual system with high flow cats, located about where the pre-cats sit and an x-pipe. this will keep cabin noise down to tolerable levels and I promise it will pass ANY sniff test.
However, it will fail a visual inspection in an instant. The upside, is that only CA and several northeastern states are requiring visual inspection.
Finally, before we start to collectively hate on big brother, I laud the effects of the EPA re: auto emissions. Do you really think that we would have clean 500+hp engines that can get 26mpg highway on their own? No, I don't.
What are you trying to accomplish? I don't mean "Why, I want to gut the cat you dope".... I mean WHAT are you trying to accomplish by gutting the cat?
Your car is an older one and therefore depending on your state, they're going to shove a probe up the pipe to test the emmisions just like on my 95 and I do not believe that you will be able to pass emissions with a gutted cat.
However as stated above had to install muffflers instead of eliminators because of extra. noise
What happens is this: An area has high ozone readings. This is caused by a lot of traffic and climate conditions. The EPA gets a hard on and tells the state that something must be done about the polution. Depending, it could mean that the region is required to test emissions.
For example, FL will not see EPA testing anytime soon thanks to the nature of the tradewinds... all the crap gets sent out to sea, one way or the other.
I used to live in Delaware, and Northern Delaware was under different emissions testing requirements than Central and Lower Delaware. All because of population and the transferance of pollution from the big urban centers (Philly, Baltimore, etc).
The bottom line is this: In many parts of the country, EPA requirements are unenforced mandates. It is still illegal to modify the emissions of your car, regardless of where you live, but it does make it less likely you will get caught.
My fear is that the EPA will one day come down on us... and all the loopholes will be sucked away.
As for a cat for your Vette, you can get high-flow cats for about $100.00 that will remove the stink and be quieter than the muffler.
there are good reasons for everything....
with Bogus and others regarding the EPA. But, to answer your question, you just remove the cat and take a hammer, a pipe and beatthe heck out of the honey comb inside the cat until it's all out. I gutted a cat when I lived in Kalifornia, at the time thay had road side tests and used the sniffer-I never failed an emissions test! I also believe polution has more to do with an unmaintained (car seldomly tuned) poor running car even with cat(s).
