Ses Light Mystery
Old Feb 15, 2006 | 02:46 PM
GIMMESOME's Avatar
GIMMESOME
Default Ses Light Mystery
Hello all , maybe someone has an answer to my question , or had this happen.Almost every time I drive my '86 to work, 11 miles, at exactly
7 miles the ses light comes on and stays on till I get to work and shut the car off.
When I start up again to head home, light is off and stays off for the ride back home, same road , pretty much the same speed, maybe a little more stop and go on ride home.I've even tried going a few miles more to see if it would come on, it dosn't.
I've checked for stored codes ,there are none, and car runs fine, no problems, even with light on. I was thinking loose connection , but exactly 7 miles ? And whynot 7 miles back under same conditions?
Weird uh?
Old Feb 15, 2006 | 03:15 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Interesting I'd be curious to see what a real time data scan looks like at exactly the time it throws the code. That might help you trouble shoot. Do you have a scanner?
Old Feb 15, 2006 | 03:19 PM
GRX's Avatar
GRX
With mine I had the same thing. It was the EGR temp sending unit/wiring.
Old Feb 15, 2006 | 04:45 PM
CFI-EFI's Avatar
CFI-EFI
It should have a stored code. Do you at least get the "12" codes? What does your factory service manual say to do in a case like this?
RACE ON!!!
Old Feb 15, 2006 | 04:52 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I agree with CFI and I bet the code is a code 32.Bad EGR.You can take it to Autozone to get the code if you want or you can do a search on how to pull codes.
Old Feb 15, 2006 | 05:03 PM
EvanD's Avatar
EvanD
CF Community Team
The reason you don't get it going home is it takes 7 miles of continuous highway speeds usually above 70 mph. My 92 does the same thing but I haven't replaced the EGR yet because the car runs fine. You should be getting a code 32 on your computer. It might be a EGR on yours, or could be the solenoid, low vacuum, or wireing...
Jerris's Avatar
Jerris
Old Feb 15, 2006 | 06:56 PM
GIMMESOME's Avatar
GIMMESOME
Hi,no unfortunatly I don't at this time,I did the jumper method.
Old Feb 15, 2006 | 06:59 PM
GIMMESOME's Avatar
GIMMESOME
RACE ON!!!
Hi, yes I do get the 12 codes but nothing after.12,12,12 12,12,12
end of story.
Old Feb 15, 2006 | 07:31 PM
Redeasysport
That does not make sense. Any time the ses light comes on it stores the code in the ECM.Unless you reset it there should be one.Take it to Autozone and have them pull the codes.
Old Feb 15, 2006 | 07:32 PM
Morley's Avatar
Morley
I've found that if the check engine light comes on due to a code 32 and later goes out on its own, the ECM won't always store a code.
Old Feb 15, 2006 | 08:21 PM
Redeasysport
That may be true mine stayed on till the car was shut off and restarted.I assumed his was the same.
Old Feb 15, 2006 | 10:55 PM
GIMMESOME's Avatar
GIMMESOME
Well everyone , I think I figured it out,my car is telling me it dosn't want to go to work,it wants me to take it home and spend all day working on it!!!!
I checked the manual about the EGR solenoid, it's suppose to be by the distributor in the right rear.
It's not.There is a pipe wrapped in aluminum foil with a thingee on top that a wire is attached to, the wire connector was wasted to I repaired that.I traced the vaccuum lines from the EGR valve and they go to what I believe is the solenoid under the throttle body on the left front side,at least it looks like the picture,and that sucker is hunkered down pretty good in there.I will attempt some more research tomorrow.
I think the ECM is ok ,because I have gotten codes before ,and corrected the problem ,than cleared them.
Thank you all for your help!!!
Old Feb 16, 2006 | 07:55 AM
rick lambert's Avatar
rick lambert
I beleive the wire your talking about is the EGR switch-my 87 was
doing the same thing-don't know about the mile thing-but it was always
on my short trip to work. I was able to read mine though and it was
a code 32-but from most of the reading and post I've read it seem
the majority of the time a code 32 is thrown-it's usually the EGR switch-it was in my case. Good Luck.
Old Feb 16, 2006 | 10:03 AM
scmboy's Avatar
scmboy
RACE ON!!!
I'd look for a shop manual on ebay.
Much cheaper usually.
Old Feb 16, 2006 | 03:46 PM
GIMMESOME's Avatar
GIMMESOME
Hi,thanks for the help.
You know,I don't think my '86 is even suppose to have this pipe unless someone said , it had aluminum heads,which it dosn't according to my RPO sheet, and a magnet.O well,another mystery.
Old Feb 16, 2006 | 06:43 PM
CFI-EFI's Avatar
CFI-EFI
My parts book shows the the EGR exhaust gas tube, on an '86, with no qualifications. Also all '86s used the same intake manifold.
RACE ON!!!
To Ses Light Mystery
Old Feb 16, 2006 | 07:21 PM
GIMMESOME's Avatar
GIMMESOME
Well guys,I am going to give this a more serious look see this weekend.
Re pull the codes,check the EGR valve , and solenoid for proper function
according to the service manual test procedures.It passed california smog just 2 months ago and I haven't driven it that much,and their real
sticklers for EGR valves.I will keep you posted on what I come up with.
Thanks again for all your input!!!
Old Feb 17, 2006 | 10:12 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
That wire is part of a one-piece EGR temp switch assembly.
On your 86 it is: GM# 14087415 - SWITCH, EGR VLV TEMP IND (1986)
A new one is about $15 from the dealer and takes a few minutes to replace. If it is not working correctly you will see an SES light and it should set a code 32. Although a code 32 is usually stored, if the wire or the switch is subject to an intermittant voltage problem that is very short or limited, as Morley says, the ECM may not store the code.
As EvanD says, it usually takes a few minutes of highway or other operation before the ECM starts looking at the EGR switch. At that time yours is replying with a suspect value and the SES light is being set. I don't advocate throwing parts at a problem, however, even though you say that you you repaired the "wasted" wire, there is probably internal corrosion in the switch wire that you missed. Replace the wire/switch assembly and I'll bet that your problem will be solved.
Old Feb 17, 2006 | 11:14 PM
GIMMESOME's Avatar
GIMMESOME
Thank you Mike,It wouldn't supprise me if that wasn't my problem,it is intermitent.
So this sensor should be a one piece thing, like a O2 sensor,right?
I noticed there is a connector for it about 6" away , so that makes a good point if it's suppose to be one piece,and
that my repair connection is faulty at the the sensor ,or the sensor is bad.Like I said, this weekend I am going to give this thing a total diognostic according to the FSM.
I will keep eveyone that has given me help posted,thanks!!
