2 month old WP failed! '94 Vette
Old Feb 16, 2006 | 06:56 PM
Ricks94vette's Avatar
Ricks94vette
Default 2 month old WP failed! '94 Vette
Has anyone every experienced a failed WP after just 2 months. Coolant leaked out of the weep whole and appears to have fried the BRAND NEW opti. SH*T!!!!!!!!!!!!!!!!!!!!!!!
I've called GM Technical and they said the WP would be covered but if anything else was damaged as a result of the WP failure, it would most likely not be covered.
Has anyone ever had success getting GM to cover "at least the cost of the Opti" because of a failed "new" waterpump? All parts were purchased from a Chevrolet Dealer. Labor was done by the mechanic at my office and I made sure everything was done right.
Any legal recourse? Small claims? Something?
Totally Bummed,
Rick
Old Feb 16, 2006 | 07:09 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Sorry to hear it.Did they install the Opti?If they did they should fix it all.They screwed it up(with their part) and should have to repair it.
Old Feb 16, 2006 | 07:19 PM
Ricks94vette
My mechanic installed all of the parts, including the new raiator and I know he did it correctly because I was there (our shop) to oversee.
Old Feb 16, 2006 | 07:43 PM
Redeasysport
You got a grey area here.The parts should be under warranty however they can deny the opti because it was not defective and say it was your fault.I would have a heart to heart with the manager of the dealership and explain what occured and have the WP as proofthat it drained on the opti and see if he can cut you some slack and replace both.Hope it works out for you.
Old Feb 16, 2006 | 11:13 PM
RED-85-Z51's Avatar
RED-85-Z51
no, but Ive had 2 alternators go bad in the same week.
1 stopped charging the other had defective bearings.
Old Feb 17, 2006 | 12:08 AM
cv67's Avatar
cv67
St. Jude Donor '05
Your best bet, sorry to hear about that.
Old Feb 17, 2006 | 12:22 AM
hippy's Avatar
hippy
Maybe what you could do is take the pump apart smash it from the inside-out, destroy the bearings in it then put the POS back together and tell the FRIENDLY overpriced GM parts counter jerkwad that their pump caused a catastrophic failure and physical damage to your Opti.
P.S. Smash your Opti with the same hammer. Don't overdo it though.
To 2 month old WP failed! '94 Vette
