shudder and shake
Old Feb 17, 2006 | 12:18 PM
rightofway's Avatar
rightofway
Default shudder and shake
when going down the road in OD in the 20-30 mph range my car feels like it's being jackhammered on it is a really violent shuddering and forces me to shift it down to D whch stops it, consiquently i ride around in D until over 40 mph
also at certain speeds and if i lightly accelerate it shakes everything up.
is this a tranny prob or TCC prob?
i'm tired of the screws falling out and watching my gauge cluster bounce up and down
help me please
TIA
Old Feb 17, 2006 | 12:23 PM
rightofway's Avatar
rightofway
forgot to mention
TH700R4
76500 mi
never rebuilt
Old Feb 17, 2006 | 05:52 PM
Pete K's Avatar
Pete K
Probably torque converter.
Old Feb 17, 2006 | 05:53 PM
Pete K's Avatar
Pete K
Be careful and get it fixed. It can shake the thrust bearing out of the motor.
Old Feb 17, 2006 | 06:15 PM
CorvAdel's Avatar
CorvAdel
"thrust bearing out of the motor.." Pardon my ignorance, but where and what is this thrust bearing in the motor..?
Old Feb 17, 2006 | 07:21 PM
Pete K's Avatar
Pete K
The engine has 5 main bearings. The rear bearing has lips that overhang the main bearing saddles. The 'lips" on the bearing ride against a flange on the crank. They work together to hold the crank in place(foward and rearward) If a clutch or torque converter put high force on the rear of the crank, it burns up the thrust bearing and "knocks out" the thrust. .005-.015 is typical thrust with .008 being about average.
Old Feb 17, 2006 | 07:52 PM
CorvAdel's Avatar
CorvAdel
...I know exactly what you mean now...didn't know they were called thrust bearings. What we ( in Australia) know as thrust bearings are the ones that operate off a clutch throw out arm/fork in manual transmissions. But thanx for clarifying that...
Old Feb 17, 2006 | 08:08 PM
CorvAdel's Avatar
CorvAdel
Pete.....Speaking of shuddering...in my 87 A4 I had a trans oil leak after rebuilding my car. This included having a trans seal kit fitted and rebuilt tc. It started leaking within 300 miles. Turns out that the fr. bearing was pushing on the lip of the seal....Remove trans. , fit new bearing, Loctite bearing in, new seal, trans. back in. I then used the car in an autocross style event, and the front seal blew out again...!
I had the trans. rebuilt again, this time with a new fr. bearing, cross hatched mating surfaces, Loctited, and peaned in place....
The question now is...do I need to balance the drive-shaft, even though there is no vibration evident while driving, or was the last fitment sufficient to prevent the seal blowing out again..?
Any input on this appreciated.
Old Feb 17, 2006 | 08:40 PM
Pete K's Avatar
Pete K
GM used a small tin ring that tapped over the front seal as a band aid fix for this type of problem. What you are describing was a common problem on the 85 and prior pumps. GM drilled the drain hole in the pump housing larger to aleviate some of this. The larger holes and pump seal retainer were(combined) a good fix. Rather odd to have happen on your unit. Maybe an 84 unmodified trans was swapped in earlier in it's life? Hopefully you have the problem licked. I would certainly try rotating the driveshaft 180 degrees. The shaft and yoke had paint marks on eack to indicate the heavy side. Most guys see this and line them up, when in fact, they should install them opposite of each other.
Old Feb 17, 2006 | 09:00 PM
CorvAdel's Avatar
CorvAdel
Gotta hand it to you, Pete..you know your stuff. My car is a "bitsa"...86 body, 87 motor and 85 trans., with a later model pump(11 or 13 vane, can't remember).
I fitted the drive-shaft without the yoke being removed before-hand..
Thanx for the tips on the oil pump housing..
Old Feb 17, 2006 | 09:18 PM
Pete K's Avatar
Pete K
Thanks, I made the 700r4 my pet project for the past couple of years. I am an info junkie and try to save every bit I learn. I can check and see the exact size of the drill for the passage and the exact procedure, in the unlikely event it bites you again. Wish you the best though.
Old Feb 18, 2006 | 10:50 AM
rightofway's Avatar
rightofway
i was hoping it wasn't something too expensive
would a reputable tranny guy be able to determine what the problem is before i shell out the big $$?
can i tell what year my tranny is? (although i'm pretty sure nobody has ever laid a wrench on this car)
will this from madvet help because it seems that the tcc is locking up when i don't want it to
Old Feb 18, 2006 | 11:04 AM
Pete K's Avatar
Pete K
A reputable trans guy will absolutely be able to diagnose that problem. Not many things it could be.
I have used that kit from MAD and it works well. I stopped using it because I typically install a 1 wire lock up, 4th gear only kit in most I do. They simply and inexpensively cause the trans to lock the converter in 4th gear only. I too like the drivability this way. No bucking or rumbling from the converter being locked up too early.
On the pass side of the case, just above the pan gasket, in the rear there is a flat pad with numbers stamped in it. Grab a brill or scrubbly pad and some carb cleaner. get the code and post it. I will decode it for you.
To shudder and shake
