Upgrade 85 ECM?
Old Feb 19, 2006 | 05:49 PM
MrNuke's Avatar
MrNuke
I too have removed the 9th injector years ago when I switched to the Superam setup.. Never a problem, other than it tok an extra second to start the car.. I fixed that easily in the chip..
Old Feb 19, 2006 | 07:19 PM
GRX's Avatar
GRX
Ski_down_it is right. There is only one real advatage of upgrading to a later ECM. That would be the MAF burn off module. The '85 are darn expensive used. The late ECMs use two simple relays to command the MAF sensor.
Old Feb 19, 2006 | 11:39 PM
nonetooclose's Avatar
nonetooclose
If this is the case, then it would be an easy matter to design and build a simple circuit to do the same that the ECM is doing without the expensive part?
What is this part, where is it located, and why is it so expensive ($cost?)?
Richard
Old Feb 20, 2006 | 12:06 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I've seen several modules sell on ebay for ~$50
Old Feb 20, 2006 | 07:53 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Richard
ECMs are pretty inexpensive ~90 dollars new. You are right though, and there are probably less than 40 dollars worth of components in them.
Aftermarket ones alike, what your paying for there is someones/groups expertise and knowhow.
Old Feb 20, 2006 | 10:14 AM
onetrackmind's Avatar
onetrackmind
Listen to Ski dwn it, He always gives solid knowledgeable advice.
Old Dec 14, 2018 | 11:28 AM
RME1993's Avatar
RME1993
Hello Everyone,
Hopefully everyone is still around because its now 2018 and I have some questions pertaining to exactly this post. In the past year and a half I have just about completely torn apart my 1985 Corvette because it needed just about a complete re-build. Essentially I am running performance heads with an aftermarket/medium camshaft, Smog Delete and new injectors with my Cold Start (9th Injector) removed as well. My car runs and performs good under load. However, upon start up it takes longer than I'd like to turn over and when i'm idling, the RPM's skip around a little, Plus I dislike the factory settings for when my fan turns on. I'm trying to turn the fan on around 180F. That being said the car needs a tune, I can build an engine but I'm not experienced with ECM swaps. I'm looking at upgrading my 1985 ECM to a 1986 ECM because i'm learning that It's significantly easier for tuning due to the fact that I can program a chip to go into the 1986 ECM. Firstly, is Oski_dwn_it suggesting that I can use my 1985 ECM to accomplish what I'm trying to get done? If so, How? If I need to swap ECM's can someone tell me if the ECM's will swap/connect without having to do any splicing and I'm not sure what is implied with
"Re-pining" so maybe someone here has a step by step instruction or a link to a video as to what needs to be accomplished. All advice is appreciated.
Thanks in advanced,
Old Dec 14, 2018 | 12:22 PM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Yes and if you do take a look at my MAF which eliminates the burn off relays. greg
Old May 18, 2020 | 01:05 AM
kentsimon's Avatar
kentsimon
Cruising
Originally Posted by RME1993
Hello Everyone,
Thanks in advanced,
Hi,so I was wondering since it was just two years ago if you ever completed the ecm swap, I have collected together almost all the parts I need to complete the swap, but I am still trying to figure out what all of the wiring changes mean, the splices are confusing to me.
Old Feb 26, 2025 | 12:03 PM
judy marie's Avatar
judy marie
Default 1985 corvette
Originally Posted by Morley
By all means do it now...for one simple reason. If you do it at the same time that you do the engine swap and the engine won't start or run right, you'll be troubleshooting 2 major systems as the possible problem. If you do it now, and get it all running correctly with your current engine, you'll have one less potential headache later.
As far as it being a "difficult" upgrade, hogwash, I did mine in 3 hours. Just some simple repinning of the ECM and some splicing of the wires at the ECM connectors. If you'd like I can give you a detailed run through of how I did it and the differences between what I did vs the directions on the (most used) web page.
The only problem I can see is that if a smog station ever has to hook a scanner to it, and that scanner uses the vin for its means of deciding which ecm file to use... it might have fits.
with 165 ecm update does system have to be flashed
Old Feb 26, 2025 | 12:44 PM
kentsimon's Avatar
kentsimon
Cruising
Default You will also need a chip
The old chip will not be compatible with the upgraded ecm. You will want a chip that matches your automatic or manual transmission for the new ECMS original year. I got a chip from an 87 automatic, but I still have not done the swap.
