LT4 HOT Cam install questions
Old Feb 18, 2006 | 08:20 AM
LannyL81's Avatar
LannyL81
Default LT4 HOT Cam install questions
When installing the GM LT HOT Cam into a stock LT4, what else needs to be changed? Springs? Lifters? Timing chain?...etc???
Thanks,
LannyL81
Old Feb 18, 2006 | 08:51 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'd say it depends on the miles and how you're going to use the car. On an LT4, you could just go with the cam. Personally, I'd do more, better springs and an electric water pump so you could install a double roller timing set while you're at it.
Old Feb 18, 2006 | 12:08 PM
FELNGR8's Avatar
FELNGR8
Thanks,
LannyL81
If an LT4 you need just the cam.
With an LT1 you need everything in the Hotcam Kit as sold by GMPP dealers, including roller rockers and LT4 springs. LT1 valve springs aren't up to the task.
To LT4 HOT Cam install questions
