Has anyone ever converted a 1984 to coil over shocks? if so, what kind of problems did you encounter? what do you think about a 400 lb spring? Is that a good all-around spring?
I am running 375lb in the front and 250lb in the rear of my 1990 ZF6 and I have found that is perfect, as the 84 is lighter than the 90 I would think slightly lighter springs would be fine, good luck
