Stuck Exhaust pipe: how to remove?
Old Feb 18, 2006 | 10:05 PM
sothpaw2's Avatar
sothpaw2
Default Stuck Exhaust pipe: how to remove?
I am trying to retreive my Power effects Cat back exhaust from my car. Removing most of the system was relatively painless, except the front two pipes that go to the cats.
I finally got the 3rd bolt for the left one last week.
The right is a night mare and that is what I want to ask about--
--It is supposed to be just a slip fit joint onto the cat's integral pipe. Well, it don't slip!! What do I do? I tried PB blaster but I don't see how it can penetrate. Do I need a torch or will a hair dryer help at all? Hammer?
Old Feb 18, 2006 | 11:56 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Patience would be the key word here. Keep soaking it with penetrating oil, if need be you can do some minor heating with a propane torch. This should come pretty easily unless it's been seriously clusterf**ked by a major idiot. I think you'll be fine.
Old Feb 19, 2006 | 07:14 AM
sothpaw2's Avatar
sothpaw2
Does the PB Blaster qualify as a really good penetrating oil? How do I get it
to penetrate best? I would think spray in the seems.
Major idiot--well--there is a lot of overlap in this slip fit and I have to wonder.
Old Feb 19, 2006 | 08:06 AM
Corvette Kid
Yeah, PB is good.
To Stuck Exhaust pipe: how to remove?
