I'm currently adjusting my valves: Roller Hyd. Lifters / Roller Stainless steel Rockers; and noticed one of the locking allen set screws sits LOWER than the others. After adjusting shouldn't they all be more or less the same height with respect to the retainer nut? Do I have a collapsed lifter?
I agree...repair manuals can suck, as can opinions like ..DO soak lifters in oil, DON'T soak 'em, adjust until you can't move the push UP and DOWN, others say until you can't TURN it, then go an extra 1/4, turn or 1/2 turn or 3/4 turn or FULL turn ...
I am starting to like the sound of old school methods. Talking of that, when you run the motor and re-adjust, how much do you turn the adjuster after clicking has stopped....none, 1/4...1/2..? And, do you you use the same amount of adjustment for roller tappetts as you do for the stock pressed ones...?
TIA
