Idle Issue
Old Feb 21, 2006 | 02:14 PM
C4CBF's Avatar
C4CBF
Default Idle Issue
Ok got a major vac leak solved, don't ever over torque intake gaskets... Anyways my 86 L98 runs fine at idle for 2-3 minutes and then the RPM's start dying down slowly until it wants to quit. The remedy is to lightly tap the gas and it goes back to normal. Any ideas?
Old Feb 21, 2006 | 02:26 PM
CFI-EFI's Avatar
CFI-EFI
Have you:
1.) Checked and corrected any trouble codes?
2.) Cleaned the IAC valve and passages in the TB?
3.) Checked or set the minimum air adjustment?
4.) Checked or set the TPS?
Lately?
RACE ON!!!
Old Feb 21, 2006 | 05:08 PM
C4CBF's Avatar
C4CBF
Originally Posted by CFI-EFI
Have you:
Lately?
RACE ON!!!
1)Don't have diagnostic equipment so I haven't checked it.
2)I took the TB off and sprayed it down good with carb cleaner. However but i think I could have done a better job. Should I take off and clean more throughly?
3)How do I set minimum air adj?
4)Sorry to sound dumb but what is the TPS? Throttle Position Sensor? How would I set it.
Thx for the info
Old Feb 21, 2006 | 07:44 PM
CFI-EFI's Avatar
CFI-EFI
1.) You can't beg borrow or steal a paper clip or similar scrap of wire?
2.) Yes.
3.) www.helminc.com
4.) www.helminc.com
RACE ON!!!
Old Feb 21, 2006 | 09:02 PM
C4CBF's Avatar
C4CBF
2.) Yes.
3.) www.helminc.com
4.) www.helminc.com
RACE ON!!!
Paper clip...hmmm that sounds intruging. But don't you need something that can recieve and decipher the info?
Old Feb 22, 2006 | 01:33 PM
CFI-EFI's Avatar
CFI-EFI
To "recieve": Eyeballs.
To "decipher": www.helminc.com.
To properly trouble shoot the codes: www.helminc.com.
RACE ON!!!
Old Feb 22, 2006 | 01:43 PM
Cashmo's Avatar
Cashmo
Yes, you'll want a shop manual. Until then this thread may be of some help.
Jeff
Old Feb 22, 2006 | 06:45 PM
C4CBF's Avatar
C4CBF
RACE ON!!!
I guess where I was going with that is where are the trouble codes displayed?
Old Feb 22, 2006 | 08:12 PM
CFI-EFI's Avatar
CFI-EFI
As your new factory service manual will explain, it is in the counting of the flashes of your "Check Engine" or "Service Engine Soon" light.
RACE ON!!!
Old Feb 23, 2006 | 12:22 AM
MikeC4's Avatar
MikeC4
As your new [URL=http://www.helminc.com factory service manual[/URL] will explain, it is in the counting of the flashes of your "Check Engine" or "Service Engine Soon" light.
RACE ON!!!
CFI-EFI - with all due respect, i think the following site is a better source of information:
http://forums.corvetteforum.com
you made 5 referances to Helms......any connections here?
Old Feb 23, 2006 | 01:12 AM
Insane1's Avatar
Insane1
It's his way of saying to buy a manual and figure out how to do it yourself. He doesn't get any kick-back if anyone buys the manual.
Old Feb 23, 2006 | 11:38 AM
CFI-EFI's Avatar
CFI-EFI
The reason for the multiple references was the lack of response to them. It's like the old joke about training an elephant. FIRST you have to get his attention. No doubt the forum is a great source of info. However with many questions come erreoneus, slanted, and sometimes, just plain WRONG info. The more one knows, the less dependent they are on the well intended but misinformed responses. A little independent knowledge helps one separate the wheat from the chaff.
After all this time... NOW you tell me!
RACE ON!!!
Old Feb 23, 2006 | 07:42 PM
Insane1's Avatar
Insane1
RACE ON!!!
Sorry to be the bearer of bad news.
To Idle Issue
