I still need help with wheel offset
Old Feb 21, 2006 | 07:30 PM
redvette6spd's Avatar
redvette6spd
Default I still need help with wheel offset
I am looking at a set of 4 used Fikse FM/5 wheels. The fronts are 10" with a 68.5 offset the rears are 11" with 68.5 offset also will they fit my 96 coup. HELP
Old Feb 21, 2006 | 07:34 PM
MYCoupe's Avatar
MYCoupe
I would tend to think that they are not going to fit w/o rubbing on the inside, especially in the rear. Just for comparison, a 17x11" rear GS wheel has an offset of 50mm so these are going to sit in an additional 18.5mm.
Old Feb 21, 2006 | 08:52 PM
USAsOnlyWay's Avatar
USAsOnlyWay
When in doubt call Fikse and ask what offsets for those particular sizes they recommend for your vehicle.
Old Feb 21, 2006 | 09:40 PM
mseven's Avatar
mseven
I agree, and they can tell you exactly how much you can bend offsets dimensions on these cars. I called once regarding that and sizes like 10.5x17 etc.
Old Feb 21, 2006 | 10:43 PM
redvette6spd
I called Fikse and they were not certain ether. The offset of these wheels is not the offset they offer for a C4 but they could not tell me they would not work ether. damn
Old Feb 21, 2006 | 11:48 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
50-56 mm are the perfect offset for your vette. Because the Fiskes are 68, they will sit at least 1/2" further into the wheel well even if they don't rub. Not sure if you'll like that.
Your other option is to get 3/4"-1" hub-centric adapters (or spacers). I'd choose the adapters because they don't require changing studs and are more easily reverseable. Plus, I think a good billet adapter is probably better than a spacer (safety).
Do a search on adapters or spacers in this forum and you'll find posts where I explain why less than 3/4" changes aren't a good idea.
If you use 3/4" spacers or adapters, your wheels will protrude very slightly (about 1/2"). If this or the internal problem of rubbing doesn't excite you, go a different route!
Old Feb 22, 2006 | 01:57 AM
USAsOnlyWay
But since you are dealing with different size wheels. They might still look right on your Vette.
I don't know.
Are they local, can you try them on?
What were they on before?
Old Feb 23, 2006 | 09:16 PM
redvette6spd
I don't know.
A C5
Old Feb 23, 2006 | 10:42 PM
vader86's Avatar
vader86
if they were on C5 and had no issues then they should fit you fine
Old Feb 24, 2006 | 02:06 PM
USAsOnlyWay
Old Feb 24, 2006 | 02:20 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I remember reading that to fit a 11 inch wheel within the fenderwell of the Vette you need a 8.3 inch backspacing. Well, if my math is right you have exactly 8.22 with the Fikse. And they are a company that will custom fit them to a certain vehicle, so I imagine they are right on in the rear.
I narrowed my rear and additional 13mm, and mine are almost flush with the fenderwell with my 50 mm offset GS wheels. So Imagine you will be spot on.
Old Feb 24, 2006 | 03:19 PM
JohnyH's Avatar
JohnyH
http://www.idavette.net/susp_chart.htm
The above link shows the 11" GS at 50mm offset, I have them on my 88 and on a really, really hard day doing laps they did rub. Only on one side think I need to look at a possible problem on the suspension!
To I still need help with wheel offset
