it never quit's..
Old Feb 21, 2006 | 09:22 PM
pr0zac's Avatar
pr0zac
Default it never quit's..
BREAKING!!!wtf.... ok so yesterday was the first time i heard it.. thought it was the starter. nope everytime i press the clutch to the floor it seems that the release fork is scraping the pressure plate.. how i have no idea.. why it would be doing this.. the clutch works fine. the last time i heard that noise the fork had come off the pivot ball but the clutch would NOT even work...did i bend it or something?? it isn't making any other noises except when the clutch is to the floor??
Old Feb 21, 2006 | 09:39 PM
rickslt4's Avatar
rickslt4
When my 96 did this it was the clutch pivot ball which had backed out of the bellhousing. Simple to fix, hard to get at!
Old Feb 21, 2006 | 09:55 PM
pr0zac's Avatar
pr0zac
that is what i was thinking too.. i know i tightened the hell out of that thing. and the locking screw that cost me $30 cause someone decided to strip the threads off(previous owner) and rtv it in place. i would like to thank that bastard.. did you use locktite on it.. i was thinking of just replacing the clutch at the same time but for the one i want and a new flywheel it kinda crushed my broke behinds dreams.. but i think with the addition of nitrous by the end of the month.. perfect timing... i will soon be needing to upgrade that puppy anyway. so i will be well versed i guess at pullin the tranny.
Old Feb 21, 2006 | 10:02 PM
rickslt4's Avatar
rickslt4
I cleaned the heck out of everything and used blue loctite, torqued it to factory specs. So far so good. Man that tranny was a bear to pull. I read about guys that do it in a few hours and I feel humbled.
Old Feb 21, 2006 | 10:21 PM
pr0zac's Avatar
pr0zac
yeah.. i had to take it out once cause while installing the engine i knocked the fork off the ball. well i never have had the pleasure of trying to pick up a heavier tranny in my life. for pete's sake that thing is a pig. i hope to have a lift and tranny jack available this time.. i am only 129 lbs.. i thought i was going to blow a blood vessel getting that thing back on the jack.
Old Feb 21, 2006 | 10:30 PM
rickslt4's Avatar
rickslt4
I put a B&M shift kit on mine when I did the clutch and was shocked at the weight of the trans. I'm back into my driveshaft as I ppicked up a vibration during this ordeal. Those c beam nuts are sure fun!!
To it never quit's..
