Code 53 System over voltage. WTF???
Old Feb 22, 2006 | 12:39 AM
kopbet89c4's Avatar
kopbet89c4
Default Code 53 System over voltage. WTF???
I was on the highway cruising home at about 80 mph and then the SES light suddenly pops out of nowhere. Car was stumbling a little and the SES remained on for about 1 minute, then off. Got scared and pulled over to the side and got out my handy paper clip. I was suprised to see a code 53. I guess my alternator is shot again but how can this happen when my alternator is only about 4 months old??? What a POS!!! When I started up the car again, the display read 15.9 volts idling, then back to cruising home again, I saw 16.3 volts and stayed up there for awhile without setting off the SES light, and settled back down to 15.5 volts back home. What could have suddenly cause a voltage spick out of nowhere?? Would 15.5 volts hurt any electronics?? My digidash is really bright too. I know I still have my lifetime warranty for this POS rebuilt Delco Remy...
Old Feb 22, 2006 | 12:52 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Voltage spikes are a bad thing.Alternators can last years or days.I read back some time ago about if the diodes go bad it will inject AC voltage into the system.I suspect your diode bridge went bye bye.I would not drive it till you replace it.
Old Feb 22, 2006 | 01:10 AM
kopbet89c4's Avatar
kopbet89c4
I have my alternator out right now. Is it possible to service it myself? If so, where are these diodes located? Could I possibly go to Radio Shack and get the diodes there???
Old Feb 22, 2006 | 02:15 AM
Demonic85's Avatar
Demonic85
If you have a repair manual it will show you how to rebuild your alternator. I know you can get the parts at an auto parts store. It'd probably be cheaper just to buy a new one though.
Old Feb 22, 2006 | 08:13 AM
jfb's Avatar
jfb
Radio Schmuck doesn't carry diodes that size.
Old Feb 22, 2006 | 08:35 AM
ittlfly's Avatar
ittlfly
I've had the same problem several years ago. I took mine to a competent auto electirc shop and had it rebuilt...bearings, diodes etc. Cost about $115.
Old Feb 22, 2006 | 08:40 AM
kopbet89c4's Avatar
kopbet89c4
Are those 140 amp units worthwhile?? Mine is rated at a pathetic 105 amps.
Old Feb 22, 2006 | 10:27 AM
Ramanstud's Avatar
Ramanstud
depends on if you need the extra amps or not. If you're pulling ~13.5+ volts at warm idle with the headlights and all accessories on - then the 105amp will be just fine. Basically you want the voltage to be greater than 13 volts so the car wont stall out from low voltage while idling.
At least, it sounds good to me.
Old Feb 22, 2006 | 12:45 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
While 15.5 volts isn't ideal, you shouldn't have any long term problem there. Most of GM's electronics are rated for 16 volts continuous, and even 24 volts at cold temperature jumpstarts. The parts get warmer, obviously, when the line voltage increases, but they should be fine. If you ran the system at 15-16 volts for the life of the car, you could expect to see some reduction in lifespan of the parts.
Old Feb 22, 2006 | 01:57 PM
kopbet89c4's Avatar
kopbet89c4
Just did an free exchange and handed back the core. Advanced Auto followed though with their warranty plan after I yelled at them for awhile and asked to speak with the store manager. I bet this new alternator will go before next year or so. Talk about quality, there isn't any!!!
Maybe I shall look into a 140 or 200 amp unit the next time this one breaks. I think something is causing me to eat the 105 amp ones, unless they are just normally very poor in rebuild quality.
To Code 53 System over voltage. WTF???
