Dana 44 application
Old Feb 22, 2006 | 02:00 PM
thirdtimevetteowner's Avatar
thirdtimevetteowner
Default Dana 44 application
Will an early model 85 to 87 Dana 44 w/3rd member, C channel and batwing bolt directly into my 89 Convertible? Any help will be surely appreciated. Thanks,
Rich K
Old Feb 22, 2006 | 02:16 PM
CFI-EFI's Avatar
CFI-EFI
The search and the FAQ must both be broken, again. YES! You will likely have to enlarge (drill out) the holes for the camber adjustment bracket.
RACE ON!!!
Old Feb 22, 2006 | 03:26 PM
93 ragtop's Avatar
93 ragtop
If you can, get the manual driveshaft. Then change your auto yoke over to it. The reason is, the manual driveshaft is about 1 in shorter and the dana 44 is about 1 in longer.
Old Feb 22, 2006 | 03:30 PM
aboatguy's Avatar
aboatguy
Old Feb 22, 2006 | 04:03 PM
thirdtimevetteowner
Thanks for the info, but not the attitude. FYI I did do a search, to no avail, else why would I ask in the frist place, know what I mean?
Rich K
P.S. I knew the driveshaft part.
Old Feb 22, 2006 | 04:19 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
Old Feb 22, 2006 | 07:52 PM
bogus's Avatar
bogus
I am not even sure about the FAQ having the exact info he wanted. I sure don't remember adding it.
Old Feb 23, 2006 | 04:46 PM
jburnett's Avatar
jburnett
The only real difference between the early D44 and the late D44 (most 87 and all 88-up) is the diff case itself. The earlier cases (85-86 and some 87) are a thicker and heavier casting. They weigh right at 4 lbs more and can be be differentiated by the casting ridge at the top. The early cases have a wide ridge where the later ones have a narrow ridge.
I've seen the camber adjustment bracket on them both small and large so it seems to be hit or miss there.
-Jeb
Old Feb 23, 2006 | 05:54 PM
thirdtimevetteowner
Jeb, thanks for your input. Now if only the seller willl contact me.
Old Apr 11, 2006 | 02:24 PM
thirdtimevetteowner
Can anyone help me as far as which early year C4's had Dana 44's in them? Didn't all the 4 + 3 equiped cars have D44's? Thanks.
Rich K
To Dana 44 application
