Tranny cooler ?'s
Old Aug 11, 2001 | 08:50 AM
Half Fast's Avatar
Half Fast
Default Tranny cooler ?'s
What size trans cooler to get? What brand has the best kit? Where is the best place for mounting? For a 1996 LT1 ,
Thanks :confused: :confused:
Old Aug 11, 2001 | 12:19 PM
HWoods's Avatar
HWoods
Default Re: Tranny cooler ?'s (Half Fast)
Get the largest one that will fit. Mount in front of the A/c condensor in front of the radiator. B & M makes some really good one.
Old Aug 11, 2001 | 06:00 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Tranny cooler ?'s (HWoods)
I have the B&M race cooler and it dropped temps by 40F
While you're at it install a seperate fileter (screw on type) too, the perma cool one has a boss for a temp sender and comes w/ a gauge (ugly, I installed an autometer one).
Marck
Old Aug 11, 2001 | 06:17 PM
olephart's Avatar
olephart
Summit Part # BMM-70264 - $49.95. It's the proper size, best construction and has a bypass system to let some very cold fluid bypass the cooler.
If you follow directions and route it through the radiator, you will not get the cooling you are looking for. You need to bypass the radiator entirely. You will need to get another female flare to hose barb type fitting to bypass the radiator. Some plugs for the radiator are nice too.
It is very easy to mount it in front of the A/C condenser. You can use 2 of the bolts that hold the plastic spoiler (the thing that hits the curb when you park). The bolts line up very well. If you put it somewhere else, like behind the radiator or in front of the P/S cooler, you will not get much cooling.
To make the mounts cut off one end of the provided strap (4 provided) between the 2nd and 3rd hole. Put it in a vice between the 1st and 2nd hole and hammer it over to an "L" shape. Don't go to 90 degrees - approximate the angle of the A/C condenser - probably about 65-70 degrees. Use the other end of the strap and make another one.
Route your hoses before you hook them up and mount them on the cooler before you bolt it in. Remove 2 spoiler bolts and loosely attach your mounting brackets. Put the cooler in with the hoses on the top and bolt it to your mounting brackets with the bolts provided in the kit.
Finish hooking the hoses up to the 2 lines from the tranny and you are about done. Takes about 30 minutes. Remember to add a little fluid to fill the cooler.
Today I was cruising for about 1 hour at 80 mph. The outside air temp gauge was between 98 and 100. Tranny temp was 168-170. It used to be around 210 in these conditions. It will go up to 185 if I beat on it around town in this heat. I think it may even reach 190-195 in heavy traffic, but that has not happened yet.
Old Aug 11, 2001 | 07:23 PM
88WHITE VETTE's Avatar
88WHITE VETTE
Default Re: Tranny cooler ?'s (Twinnie)
I also have the B&M and it's working just fine.
Mine is mounted in front of the radiator (I don't have A/C anymore :lol: )
Ziggy
Old Aug 11, 2001 | 10:22 PM
olephart's Avatar
olephart
Default Re: Tranny cooler ?'s (tntcorvette)
TNT - I was worried about the extra heat too. Turns out the water runs a few degrees cooler - I guess it's because the heat from the cooler is less than the heat that the tranny was putting inside the radiator.
Wow, you got the monster unit. Probably great for racing or mounting in a less efficient location. I'm afraid if I had one that big that the temps would be too low - especially in the winter. Probably works great where you have it mounted.
More than one way to skin a rustang.
Old Aug 12, 2001 | 09:45 AM
Half Fast's Avatar
Half Fast
Default Re: Tranny cooler ?'s (olephart)
:D
Thanks for the help. That's the kind of info I was looking for.
To Tranny cooler ?'s
