Wiring Harness
Old Feb 24, 2006 | 09:23 AM
Kryptonite's Avatar
Kryptonite
Default Wiring Harness
1993 LT1 CONVERTIBLE
What would cause the wiring harness to heat up and eventually frie but not to the point of being on fire? Talk to my mechanic this morning and he trying to run it down. We have replaced the harness section from the firewall forward.
Old Feb 24, 2006 | 09:34 AM
RRT vette's Avatar
RRT vette
Sounds like some bare wire might have been touching somewhere. Hope the new harness worked
Old Feb 24, 2006 | 09:41 AM
Kryptonite's Avatar
Kryptonite
Default Harness
He is tryin to run it down its still getting hot even with new harness.
Old Feb 24, 2006 | 12:53 PM
blown87's Avatar
blown87
GA Events Coordinator
Something is going to ground or pulling to much amps, your wrench should be able to tear apart your old harness to see which wires were fried, at least that will give you a place to start.
I will tell you that the majority of mechanics are not real good with electrical stuff, i say that because in the last 25 years or so i have hired and let go a lot of mechanics. and the ones that are good at it do not really like doing it because there is no flat rate to beat and it is a lot of times impossible to actually charge the amount of time that it takes to find and correct a problem like this.
If i can help you on tis let me know.
Greg N
Old Feb 24, 2006 | 01:51 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
If you have the FSM it should be pretty easy to ID the culprit.Just ID the wire and what it goes to.
To Wiring Harness
