Need help!! Alternator connection broke!
Old Feb 24, 2006 | 03:50 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
Default Need help!! Alternator connection broke!
The regulator connector (plastic harness) for the alternator broke. The plastic harness broke into a bunch of pieces, so now i have to connect the loose wires to prongs on the alternator. The trouble is, there are only 3 wires, but there are 4 prongs!! Which wire goes to which prong? i don't have another vehicle right now to go to a dealership and try to find another plastic harness.. So what's the solution?
I guess since it's called a regulator connector, then it regulates the alternator output? or does it simply go to the CCM to warn of any alternator problems? Do i really need those 3 wires for the alternator to function correctly? Or can i just connect the red cable (the main connector) on the back of the alternator for it to function correctly?
Thanks.
VetteUSA
Old Feb 24, 2006 | 07:15 PM
jfb's Avatar
jfb
All the wires need to be connected.
Old Feb 24, 2006 | 07:19 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Ummm, it does sorta say that he's got hiself a 93 LT1.
Keep in mind that an automotive alternator generates AC current and that it is the rectifiers (or diodes) that change this into the DC current needed to charge the battery.
The car & it's accessories run off of the battery not the alternator which is used soley to charge the battery.
Old Feb 24, 2006 | 07:27 PM
Pete K's Avatar
Pete K
Got one for ya. Shoot me your address and it is on the way!
Old Feb 25, 2006 | 12:56 AM
tsiawd1028's Avatar
tsiawd1028
the order for for the alternator, from top to bottom is PLSF/
P Top teminal is not used,
L is for the alternator light Shuold be brown,
F is for field volatage , usually blue or purplish
S is for sense the red one
no the alternator wont just work with the red. Get a replacement connector, cheap and easy
Old Feb 25, 2006 | 02:54 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
NAPA has the connector and it is $35.00 big ones
Old Feb 25, 2006 | 08:56 AM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
Thanks guys!
Old Mar 31, 2006 | 04:10 PM
patdaddy's Avatar
patdaddy
Default Alternator Connector
I have the same problem on my '96 Collector LT1. On the connector I bought, P is black, L is brown and F is red (OK so far).
On the wiring harness, both of the small leads are the same brown color. There is no stripe or other marking to differentiate the 2.
What is the difference in voltage running thru these 2 leads? Will it matter which actually serves as P or L?
Thanks, Patdaddy
Old Apr 1, 2006 | 05:11 PM
REDC4CORVETTE
I think if you look close one is a light brown tan just slight diff in color.
Not sure Its been along time since I replaced my wires.
Old Apr 1, 2006 | 06:11 PM
Jerris's Avatar
Jerris
You can get them at NAPA. Also buy some heat shrink tubing as you will have to solder on the pigtails.
Old Apr 1, 2006 | 06:13 PM
patdaddy's Avatar
patdaddy
Default wires
Does that mean the lighter color wire in the harness goes to the brown lead on the connector and the darker color wire in the harness goes to the black lead on the connector?
To Need help!! Alternator connection broke!
