Help With O2 Sensors
Old Feb 24, 2006 | 04:17 PM
garvette91's Avatar
garvette91
Default Help With O2 Sensors
Im Currently Working On My 91 L98 And I Had The Converters Removed ,but Now Im Having Trouble With My Check Engine Light Coming On And I Was Wondering If There Is A Replacement Availible That Will Take The Place Of The O2sensors,or To Plug Off My O2sensors So That They Dont Keep Causing The Car To Run Rich. Thanks Inadvance.
Old Feb 24, 2006 | 04:50 PM
vader86's Avatar
vader86
Pull the SES code from the computer before you do anything at all. Dont start theorizing until you know what the problem is.
Your engine will not run right with the O2 sensor deleted, and you only have the 1 on the drivers' side.
If you have an O2 code, then the sensor or its connection is bad, in nearly all cases its unrelated to removing the catalytic converter.
Old Feb 24, 2006 | 04:54 PM
stubbs's Avatar
stubbs
If the sensor is before the cat there is no reason removing the cat would trigger a code. Newer style multiple O2 sensor vehicles could throw a code as the after cat sensor is designed to trigger a code if the cat stops working. But if your car is a single O2 sensor sytem thats not the issue, but Vader is right, pull your codes first, then see what needs to be addressed
Old Mar 6, 2006 | 01:44 PM
garvette91's Avatar
garvette91
I Will Try That First
To Help With O2 Sensors
