87 Climate air push button problem
Old Feb 24, 2006 | 06:37 PM
Don in Vermont's Avatar
Don in Vermont
Default 87 Climate air push button problem
Hi All,
Had an odd thing happen to my climate air push buttons. My passenger had a coke in the cup holder and it tipped over and spilled some coke in the row of the climate air buttons. Now the buttons are sluggish or stuck from the sugar in the coke. Is it possible to remove the CC unit and clean up the button slide area ? The CC works perfectly other then that.
Thanks,
Don in VT
Old Feb 24, 2006 | 07:13 PM
jfb's Avatar
jfb
Yes, use distilled water, not tap water, or use alcohol.
Old Feb 24, 2006 | 07:35 PM
Don in Vermont
Default Climate air push buttons
Hi,
Thanks for the reply. Does anyone know of a link or some tips on removal and cleaning?
Don
Old Feb 24, 2006 | 07:57 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
I completely dissasembled mine for this, and washed it out with q-tips and purple cleaner. works great now.
Old Feb 24, 2006 | 08:11 PM
Don in Vermont
Default Climate air buttons
Hi
Could you give some tips on removing the unit and opening it up ?
Don
To 87 Climate air push button problem
