Chirping noise in engine
Old Feb 25, 2006 | 05:12 PM
redaz94's Avatar
redaz94
Default Chirping noise in engine
My 94 lt1 seems to have a chirping noise about every 2-3 sec. I noticed it about a week ago. Could it be a pulley or water pump? the sound resonates in around the intake/lifter area. I replaced the oil today. The car has great performance and burns no oil and still gets great fuel economy. Does it sound serious? My serpentine belt was replaced 12,000 miles ago otherwise noting else has been replaced for at least 3 years. All help would be appreciated.
Old Feb 25, 2006 | 05:15 PM
Ramanstud's Avatar
Ramanstud
probably a belt/pulley starting to wear. Could be the A/C compressor, the water pump, the power steering pump, even the tensioner pulley.
Likely, nothing will "show" as in higher temps or whatnot, it can be hit-miss on replacing the said part depending on how good your hearing is. On the bright side, if you wait long enough it will get louder and aid you in your diagnosis!
Old Feb 25, 2006 | 05:18 PM
RRT vette's Avatar
RRT vette
I wouldn' t worry about it unless it is really loud and bothersome or you start noticing changes in temps or pressures.
Old Feb 25, 2006 | 06:46 PM
MikeC4's Avatar
MikeC4
I would not ignore it. Right now it is a warning sign. A chirp could soon develop into complete bearing seizure, and a smoked belt. Get a mechanics stehescope and try ot isolate the pully that is chirping...then repair it.
I ignored a 'chirping' sound on my Pontiac, and an idler pully seized and throught the belt off......
Old Feb 25, 2006 | 07:32 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Corvettes are sometimes like people. That noise could be the start of something expensive. Also could just be a noise that will go away without ill effect. Probably one of the best things I did when I started this hobby was to seek out a couple of fellows who know lots about cars and will offer their expertise. Get to know someone at the local parts store and ask about "corvette guys" or "car guys" who know their cars.
A knowledgeable car guy in your corner is worth a lot......
Old Feb 25, 2006 | 07:40 PM
Ramanstud's Avatar
Ramanstud
CAUTION: Most people think they're knowledgable, but only speak from limited personal experience. This may work, but don't believe just one guy. ask around and ponder before committing based on one "friend's" opinion.
Old Feb 25, 2006 | 07:47 PM
mseven's Avatar
mseven
I vote to try and find the source. Issolating may be a bit hard but I agree w/a stethascope, and don't just start replacing parts. The thing about waitng is, maybe it may get loud enough to save money buying the scope.
Old Feb 25, 2006 | 08:17 PM
aminnich's Avatar
aminnich
Try the easiest approach first. If you can't isolate the 'chirp' by listening to it then loosen the belt and spin all the pulleys. Feel for any movement, binding, or anything else one pulley at a time until you find it. I would bet on the belt tensioner pulley as that seems to usually be first one to fail. Easy test, better than having pulley freeze, burn out the belt, broken belt whip around and wipe out sensors and vac lines, and then a wrecker to boot.
Like the old ad said--"you can pay me now, or you can pay me later".
Let us know how it turns out
Old Feb 25, 2006 | 08:54 PM
JIMBO7's Avatar
JIMBO7
Oh yeah....buy or borrow a stethescope. FInd the problem. Even if nothing fails soon, you know it's there. Go get it.
Old Feb 25, 2006 | 09:10 PM
redaz94's Avatar
redaz94
Could it be internal? maybe pistons,lifters,valves or do you think I would have more issues if that were the case? By the way I appreciate you responses.
Old Feb 25, 2006 | 09:43 PM
aminnich's Avatar
aminnich
I would say no way to internal problem. Chirps are 99.9% belt related noises.
Old Feb 26, 2006 | 05:37 PM
vettef6's Avatar
vettef6
I had the same problem on my '92 a few months ago. I changed everything: belt, idler pulley and tensioner. Paid a lot of money for nothing; it turned out to be the balancer!!
Bought one from eBay and it runs great eversince.
To Chirping noise in engine
