That was easy! (Rear Bearings)
Old Feb 25, 2006 | 09:44 PM
mitchcole's Avatar
mitchcole
Default That was easy! (Rear Bearings)
Really!
Just pull the wheel;
Disconnect the caliper from the housing
Pull the rotor
Remove the castle nut
Remove the nut
Go to the backside of the knuckle where the half shaft goes in - loosen it with the torx 55 bit. That was the hardest part
Helps to have an air ratchet. othewise click turn click turn click turn....
New ones went on perfect. I picked them up from www.wheelbearingsinc.com They seem to be quality units... stamped Made in USA.
The passenger one came apart in two pieces. No other broken parts though.
Drivers seemed reasonably good - but I replaced it too.
Total time - 3 hours both sides.
Old Feb 25, 2006 | 11:05 PM
parafrog's Avatar
parafrog
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
good for you. i just ordered the same parts, and the price is unbelievable--i hope they stand up. gotta put mine on. i bought a good 55 and will try the air.
did you use the impact or a regular air ratchet? maybe i should have asked, did you break the bolts loose with air?
froggy.
Old Feb 26, 2006 | 01:55 AM
86PACER's Avatar
86PACER
Damn. I just looked them up on that site and got a price of $62.48.
How much was the shipping for both when you bought them?
http://www.wheelbearingsinc.com/Shop...ing&location=2
Old Feb 26, 2006 | 02:38 AM
parafrog's Avatar
parafrog
the shipping to az was $17.60 for two pieces. not bad.
froggy.
Old Feb 26, 2006 | 07:19 AM
MR NICE's Avatar
MR NICE
Made in the USA wonder if they are Timken?
Old Feb 26, 2006 | 08:06 AM
CAP94's Avatar
CAP94
Thanks for the info,rear bearings are my next project...
Old Feb 26, 2006 | 09:05 AM
curtismoff's Avatar
curtismoff
how can gm charge like 500 each and this place 63
Old Feb 26, 2006 | 09:33 AM
87vette's Avatar
87vette
I see they only carry the rears for the 87.. and not the front. Regardless they look great. I bookmarked their page in case I ever need to do mine.
Old Feb 26, 2006 | 09:40 AM
vetster86's Avatar
vetster86
UPS brought mine the other day, got mine from the same place.
Can't beat the price.
If I get time today I will take some pic's and post them here if anyone would like to see them.
Old Feb 26, 2006 | 10:29 AM
mitchcole's Avatar
mitchcole
I didn't use an impact to loosen them - just a breaker bar. The big gun won't fit in there. A breaker bar with a 12" extension - worked good.
Old Feb 26, 2006 | 10:54 AM
comp's Avatar
comp
Old Feb 26, 2006 | 10:22 PM
parafrog's Avatar
parafrog
BOOYAH!!!
Old Feb 28, 2006 | 05:47 PM
SK.LT1's Avatar
SK.LT1
Awesome price.Hope the quality is good.
Old Feb 28, 2006 | 05:55 PM
El Guapo's Avatar
El Guapo
St. Jude Donor '03
The only difficulty I had in replacing the rear ones on my 94 was that they both had one bolt that just did not want to loosen up. I sprayed it, soaked it, and fought with it all day long before they would give. I'll have to bookmark that page and maybe just go ahead and buy some to keep in storage for when I need to replace them again.
Old Mar 1, 2006 | 11:13 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Would a bearing removal tool help? Are they the pressed-in bearings like on my '87 BMW?
Old Mar 1, 2006 | 12:07 PM
19corvette91's Avatar
19corvette91
nope
Old Mar 1, 2006 | 09:01 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
No such luck. The bearings are part of the hub assembly.
To That was easy! (Rear Bearings)
Old Apr 12, 2006 | 04:45 PM
MR NICE's Avatar
MR NICE
Just tried to order a pair they are out till the first of May, They told me they are made by Casper in ******* Mi. the lady also said Timkin buys from Casper I don't know about that sounds like maybe some what do you guys think?
Old Apr 12, 2006 | 06:30 PM
eschoendorff
St. Jude Donor '08
Honestly, I think it's entirely possible.
Old Apr 12, 2006 | 06:58 PM
CFI-EFI's Avatar
CFI-EFI
I used a 1/2" drive air impact wrench. There was just enough wobble from the 4" extension and the 1/2 to 3/8 adapter for everything to line up.
I've never heard of Casper, but who... The part numbers on the site:
Originally Posted by Wheel Beatings Inc.
Part No's: 513020, BR930024
Look familiar. The 513020 is in my Federal Mogul book for BCA bearings. The BR930024 looks like a Chicago Rawhide part number.
RACE ON!!!
