Greg or others.. ATI balancer install help..
Old Feb 26, 2006 | 02:02 PM
lcvette's Avatar
lcvette
Default Greg or others.. ATI balancer install help..
Hey guys,
I am pulling my hair out on this thing.. checked the measurements for the interference fit and all was good, boiled the hub, have it on a good ways, key is in, shim is in, it is actually inside the seal and possibly seated.. went to remove the installer and the adapter stayed in the crank shaft.. in hind sight I now realize I should have not bottomed out the adapter fitting in the crank.. any advice on getting it out without removing the hub?
thanks in advance!
Chris
