C beam sealant/ adhesive?
Old Feb 26, 2006 | 06:06 PM
CF6873's Avatar
CF6873
Default C beam sealant/ adhesive?
What do you guys use for the sealant or adhesive on the ends of the C beam? Thanks
Old Feb 26, 2006 | 06:34 PM
Mo_Bandy's Avatar
Mo_Bandy
I haven't used any on mine... I don't hear any noises from it. I just torqued the bolts down per the factory spec. No issues to speak of..
MO
Old Feb 26, 2006 | 06:40 PM
cmontel727's Avatar
cmontel727
I used liquid nails construction adhesive from home depot. I think it was close to what GM used. Its worked fine for over two years now.
Hope this helps
Old Feb 26, 2006 | 08:05 PM
mothersworry's Avatar
mothersworry
Install it dry. As Mo said there will be no problems.
Old Feb 26, 2006 | 10:15 PM
parafrog's Avatar
parafrog
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
this question was raised a little while ago. the most logical opinion was that the sealant was to stop water intrusion into the bolt cavity and rusting the bolt. i believe it became clear that normal rtv would be adequate. but i have to agree with the liquid nails post. when i broke my beam loose-117k miles-to put in a new tranny, the crap that was on there most closely resembled liquid nails and held like it too. the stuff probably had a two-fold mission: seal the hole and prevent movement. that being said, proper torquing and rtv on the top has covered both issues for me as far as i can tell. if i had to do it again and was sure i wouldn't have to pull it off again anytime soon, i would probably go the liquid nails route.
do a search.
frog.
Old Feb 27, 2006 | 09:27 AM
GRX's Avatar
GRX
Also, you don't want corrosion starting between C beam and trans or diff. If you live where they salt the roads in winter this may be an issue.
Its easy but messy to do. I usually use grey silicone (seems easier to clean up), and I don't even live where they salt the roads.
Old Feb 27, 2006 | 04:00 PM
VMAX451's Avatar
VMAX451
I believe the official GM sealant you get from the dealer is just a tube of windshield adhesive. But seems like anything works fine, or just nothing at all. I used the windshield adhesive, but just because I'm paranoid.
Old Feb 27, 2006 | 05:26 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I just tork the front trans bolts to 39 ft lbs and the rear to 49 ft lbs.
Never used the sealent .Some use the liquid nails.
Old Feb 27, 2006 | 08:42 PM
CF6873's Avatar
CF6873
I would think that urethane windshield sealant or liquid nails would be very difficult to take apart in the future. If the purpose of the sealant is for corrosion I think I will go with silicone. Thanks guys
Old Mar 5, 2006 | 04:55 PM
Duntov85's Avatar
Duntov85
Last time I had my tranny out, when I removed the bolts out of the C-beam, water poured out. I didn't use sealer.
This time I used silicone.
To C beam sealant/ adhesive?
