Rear main seal ?
Old Feb 26, 2006 | 06:12 PM
CF6873's Avatar
CF6873
Default Rear main seal ?
Can the rear main seal be replaced without dropping the pan on a 94? Thanks
Old Feb 26, 2006 | 07:03 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Not sure about that, but you do have to pull the trans.
Old Feb 26, 2006 | 07:41 PM
CF6873's Avatar
CF6873
I have the trans on the floor ready to go to the shop. The rear main is definetly weeping and right now the rear of the engine is being held up by a jack under the pan. It looks like the seal should come out the back without disturbing the pan.
Old Feb 26, 2006 | 07:48 PM
bowtieclassics's Avatar
bowtieclassics
Default rear main seal
Yes you can change the seal only without dropping the pan. Pry it out with a little screwdriver where the indentations are. If you change the seal retainer gasket you must remove the pan or at least lower it a half inch or so.
Old Feb 27, 2006 | 07:16 AM
CF6873's Avatar
CF6873
Could the seal retainer gasket leak to the outside? Thanks
Old Feb 27, 2006 | 08:38 AM
RED LT4's Avatar
RED LT4
Yes...been there done that
Old Feb 27, 2006 | 08:45 PM
CF6873's Avatar
CF6873
Well it looks like I'll be dropping the pan to replace both the main and inner gasket. I'll have to come up with a way to support the rear of the motor. Thanks
Old Feb 27, 2006 | 09:45 PM
CentralCoaster
You could probably get a 2x4, and screw in some wood blocks to both ends of it so it cradles the crank and supports the block by where the pan would bolt up. It doesn't take much to hold it up when the tranny is off.
Either that or a cherry picker.
To Rear main seal ?
