fuel pump issues
Old Feb 27, 2006 | 12:02 AM
95PCTBK's Avatar
95PCTBK
Default fuel pump issues
new to the forum, i have a 95 six speed with a all forged 383 with a t-trim blower afr 210 heads ati intercooler and snow perf. boost cooler and walbro 255hp fuel pump thats 3 years old. what pump should i replace it with?
Old Feb 27, 2006 | 09:44 AM
mn_vette's Avatar
mn_vette
are you running low on fuel pressure?? Why are you thinking of changing the pump? I like the walbro 255lph, infact I've got two of them in my tank right now.
Adding a second would be the cheapest way of increasing fuel flow if the other one is still running fine.
Old Feb 27, 2006 | 07:40 PM
95PCTBK's Avatar
95PCTBK
i need to know should i run two pumps for high horse power. just built another motor and trying to get the fuel right. can i run two pumps with the factory fuel lines?
Old Feb 27, 2006 | 09:05 PM
lcvette's Avatar
lcvette
what kind of power are you shooting for? I think that a GSS340M and a kenne bell boost-a-pump is good to around 550-600 rwhp if you are well intercooled and running your snow kit.. beyond that, go to Greg Carroll's thread regarding pump configurations. you can run a secondary inline along with your walbro intank and get a bit more or go with a twin parallel GSS340M setup such as mine which was shown by Greg to be capable up to 1000rwhp with appropriate lines regulator and rails and injectors. just depends on your goals at this point, personally in my case I figured I would bite the bullet from the beginning and be setup for whatever my goals became and not have to bother with spending extra money down the road and be as safe as possible from square one. but thats just me.. I tend to overdo things.. you may feel it is overkill.. i see it as room to grow later..
Chris
Old Feb 27, 2006 | 09:22 PM
95PCTBK's Avatar
95PCTBK
hope to hit the 650 mark with pump gas if possible
Old Feb 27, 2006 | 09:35 PM
95PCTBK's Avatar
95PCTBK
i had a t-rex inline that came with the kit but it failed and i just ran the walbro. the old motor with 12psi ran 10.90@129 with ed wright mail tune the car ran very rich.going to let allen futral dyno tune it this time around.
Old Mar 1, 2006 | 09:28 PM
bmergner94vette's Avatar
bmergner94vette
i'm running about the same combo you are. i run 2 255lph pumps in the tank right now. i have 2 #6 lines running up to the fuel rail but it's got plenty of fuel even for my intercooler in the blue bottle.
Old Mar 1, 2006 | 10:20 PM
lcvette's Avatar
lcvette
sorry no shots of the actual twin pumps, but here is the rest of the fuel system.
1000+ HP fuel system setup
Old Mar 1, 2006 | 10:25 PM
95PCTBK's Avatar
95PCTBK
Old Mar 1, 2006 | 11:45 PM
lcvette's Avatar
lcvette
yes you can run twin pumps with the factory fuel lines.. it will require some wiring to the pumps, and a Y tying in the two pumps into the factory feed line in the tank assembly.
Chris
Old Mar 2, 2006 | 11:59 AM
mn_vette's Avatar
mn_vette
This is off a camaro, but pretty much the same thing though.
http://web.camaross.com/forums/showthread.php?t=433880
Old Mar 2, 2006 | 09:10 PM
AKS Racing's Avatar
AKS Racing
I ran dual Walbros up until the middle of last year, when I ran into a lean condition under full boost. It turns out that the pumps were having difficulty pulling fuel over the top of the tank. I wound up going to a single Weldon with a -12AN from the bottom to the pump, dropping to a -10AN to the front that splits to a pair of -8AN to the rails. I am using an Aeromotive BR regulator, and twin -6AN returns to a single -8AN back to the tank.
I have no further lean out condition, but the old Walbros pushed the car into the 9s. I think you are fine until you see a lean condition as illustrated by A/F ratio readings.
Aaron
To fuel pump issues
