Finally Got Headers - Heated O2 Sensor?
Old Feb 27, 2006 | 09:51 AM
GRX's Avatar
GRX
Default Finally Got Headers - Heated O2 Sensor?
So I finally ordered my tpis headers and was wondering how many here on the cf have opted for a heated O2 sensor? Is it really needed?
1985 L98.
Old Feb 27, 2006 | 10:38 AM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
I have the TPIS headers and a heated O2 on my '87 383 - it wouldn't go into closed loop with the non-heated sensor. It is a common problem with long tube headers as the sensor is not able to reach and/or sustain operating temp.
Old Feb 27, 2006 | 10:50 AM
GRX's Avatar
GRX
Can you post the setup? I mean which O2 sensor did you get? How did you wire the signal portion of it?
Old Feb 27, 2006 | 11:08 AM
vader86's Avatar
vader86
My 86 goes into closed loop fine without one, TPIS headers.
Only way to tell is actually hook up a scanner and see if its dropping out of closed loop at idle.
the Autozone PN for the right heated O2 is 13190
Old Feb 27, 2006 | 12:07 PM
Lars87's Avatar
Lars87
I have LPE headers, and NON heated O2.......No probelms here..yet
Old Feb 27, 2006 | 12:18 PM
byebyeL98's Avatar
byebyeL98
That is what you should do first - verify whether or not it is staying in closed loop at idle.
I bought the Bosch sensor, which included the weather pack connection terminals. It has 3 wires - one is connected to the original O2 sensor wire, one is ground, and one is connected to a switched power source.
Old Feb 27, 2006 | 01:11 PM
Slalom4me's Avatar
Slalom4me
Personally, I'd say just do it. There are LOTS of threads about this.
There is a Tech Tip with instructions and a p/n for one of the several
sensors that can be used. However, the following information from
a recent post strikes me as being one of the simplest, least expensive
and neatest ways of going about switching to a heated O2. The
complete package from Casper's is a great bargain.
"Here are a couple of links that may be useful. I wish I'd known about
the first one before I sourced/built my conversion. The second link
shows one way of tapping into a switched 12VDC source for the O2
heater.
Heater O2 sensor: Modify Aux Fan Relay for a switched 12VDC source
There are some tech tips and many other threads on the subject."
Old Feb 27, 2006 | 01:57 PM
Red Tornado's Avatar
Red Tornado
I agree. My 1rst mod was LT headers & exhaust. Back when I purchased Hooker 2149's brand new, I had them dropped shipped to HPC Coatings, Inc. and had them drill & install a relocated o2 bung on the passenger side header, at the 11:00 position, prior to them being re-coated outside and inside.
I didn't mess around with testing later on to find out whether a heated/relocated o2 would be required or not; I ain't into that kind of nonsense. I just did it. Didn't cost much, and there's nothing to worry about later.
Old Feb 27, 2006 | 03:47 PM
GRX's Avatar
GRX
hmmm. Now I feel foolish . I'm already using a WB O2 already. I could just tap into that! Wasn't using all my brain cells!
Old Feb 27, 2006 | 04:03 PM
Slalom4me's Avatar
Slalom4me
For those who may not know, Hot Rod 90's remarks about having his
pipes coated are relevant to the O2 discussion because coated pipes
are better at retaining heat - so the sensor is more likely to reach
operating temperature in coated pipes than in uncoated ones.
Ditto with stainless steel pipes.
When I installed SS pipes, I retained the unheated sensor temporarily
for expediency. I happened to log sessions and I could see that I
ought to have a heated sensor because it took a long time to go to
closed loop and under cruise conditions at 50 MPH on a cold day, my
car would go open loop. It might not have been problem in hot
conditions but I intended to go to a heated sensor, regardless.
The heated sensor warms up now in seconds, no matter what the
conditions are.
Old Feb 27, 2006 | 04:24 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
conditions are.
I have coared stainless steel headersa and ahd to go to Heated O2's this weekend. Now the smell of gas is gone and the Vette goes into Closed loop, and stays there.
To Finally Got Headers - Heated O2 Sensor?
