Anyone running a Pyrometer gauge?
O2 gauges.
Here is one member that has EGT on the car
Here is the thread: [Pics]: SloRvette's new Stealth Ram beast.
are way to many variables to give you a set temp to tune for.
stock, are there many 'tuning' options available that would facilitate
cylinder balancing or are the choices limited?
Without being able to change cylinder-to-cylinder A/F ratios or spark
events through the EFI, it would seem that more labour/time-intensive
approaches would be required.
1200 deg will give your headers a nice molten aluminum coating inside.
just remeber when running close to the edge as the temp & other
weather factors change these temps can change fast so need to tune
at the track.
a debate. It was to draw out a bit more info from someone more
knowledgable/experienced than me to help point out a few more angles
to the topic.
Some members in the forum have aftermarket EFI systems that provide
sequential injection and let them tune cylinder by cylinder. Carbed cars
don't give quite the same control (unless they have a venturi per
cylinder) but they do give you some control to tune clusters of cylinders
through jetting. A batch-fire EFI system like the OEM Bosch unit on my
L98 seems to be the least flexible of these three.
Now, you don't say what your combination is. If it has a stock EFI with
batch-fired injectors then I feel that it is necessary to tune to the
lowest common denominator (the leanest cylinder) because you can't
do much easily** to change the imbalance between the lean cyl and
the other richer cylinders.
Where to mount the probe(s)? IMO, a probe should be mounted as
close as practical to the target cylinder. This helps improve accuracy
and speed of the reading displayed.
How many probes? For a given set-up, you might find information that
indicates cylinder X is the one that always runs lean - if so, place a
probe in the primary for this cylinder. However, if your set-up is
different, then you can't be sure that cyl X runs lean on your car -
maybe a different manifold, headers or whatever means that on your
car, cyl Y runs lean. Keeping in mind that you need to tune for the
lowest common denominator, you'll need to install thermocouples in all
eight primaries to be able to determine what the EGTs are in your case.
Or risk melting stuff.
The ** asterisks:
If you are stuck with or commited to a batch-fire EFI, then you need
to find other ways of adjusting A/F ratios. These could include
selective porting work, mixing/matching rocker arm ratios, custom
cam grinds, even simple stuff like blocking port flow with gasket overhang.
The caveat:
My experience with EGTs was with multicylinder 2-strokes, Mikuni carbs
and expansion chambers. I can tell you that if the needles went much
beyond 1350ºF on my setup, then I was going to be facing a cold walk
back across the lake. Like I said up top, it is up to others with more
direct C4 experience to say how applicable my info is to your situation.
I still think that WB-O2 is an improvement, at least for those of us who
are not at ten-tenths. For those who are and who have the supporting
systems to optimize cylinder balance, Innovate has a deal allowing you
to place O2 sensors in each primary and log up to 16 cylinders
simultaneously.
HTH and I'm keen to hear from others.
My car has a sequential FAST so I have control of individual cylinder fueling and timing.
I've seen 1480's WOT NA with no issues. Ignition timing plays a big role in where EGT's will fall. 1000 to 1100 at part throttle cruise. 600 to 800 at idle.
feedback on the egt gauge, the more for datalogging the better
You've already made the investment in hardware, installation and learning
curve. Why not use this to gather data? There is also their LC-1 Wideband
Controller - haven't done it, but I think you can use one of the LC-1 analog
outputs as a source for one of the three optional inputs that DataMaster
can log.
If it didn't matter that the A/F values weren't together with other
parameters, you could just video the LM-1 display.
On second thought, you don't have to ask for opinions or run individual
thermocouples. As long as you have time and don't mind drilling all
primaries, you can log runs with the thermocouple in each of the
primaries to determine what is happening in your specific combo.
If you are reasonably good at reading plugs then you should be able to
narrow down which cylinders to start with.
I would start with a rich configuration and work towards the lean side
cautiously. Detailed records (including atmospheric conditions) ought
to be kept. Double check results across the leanest cylinders
periodically or when really getting to the fine edge.
Good luck whichever route you take. Post back with your experiences.
BTW I have one in the first cylinder pipe, cause that was the cylinder that burned up when I experimented with a too lean mixture.
