C4 line lock , how to
Old Aug 12, 2001 | 02:25 AM
righton's Avatar
righton
Default C4 line lock , how to
How do you make a line lock work? When in the instructions of the line lock brake says that it will not work ,with anti lock brakes.How do I make the line lock workJOE rightonjoe@earthlink.net :chevy
Old Aug 12, 2001 | 02:28 AM
KLLRVET's Avatar
KLLRVET
Default Re: C4 line lock , how to (righton)
The line lock works fine with anti-lock brakes. I installed mine about a year agao andit works flawlessly
Tony
Old Aug 12, 2001 | 04:23 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
It will work with ABS because once you activate the line loc, your foot isn't on the brake pedal, so it doesn't know the front brakes are engaged, therefore, it works. Make sure ASR is off.
Old Aug 12, 2001 | 01:31 PM
righton's Avatar
righton
Default Re: C4 line lock , how to (Mr Mojo)
My line lock is installed between the master cylinder and the anti lock unit. The locking will not hold the car no matter how hard I push on the pedal before applying the lock engagement solenoid, whats wrong with this ?
Old Aug 12, 2001 | 01:58 PM
Mr Mojo's Avatar
Mr Mojo
Have you tried pushing on the brake pedal after engaing the line loc? Or did you bleed the brakes after the install?
Old Aug 12, 2001 | 03:57 PM
righton's Avatar
righton
will hold on lithe throttle only
Old Aug 12, 2001 | 04:23 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
What the line loc does is it doesn't allow the brake fluid to return to the master cylinder after you release the brake pedal. So you pump up the brakes , hold pressure , hit the LC button to activate and release the pedal.
Thats it. If unit is installed correctly it should work. :blueangel:
[Modified by mackeyred96, 3:24 PM 8/12/2001]
Old Aug 12, 2001 | 04:31 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
So John, you just cut the front brake line(s) near the master cylinder (before the ABS) and plumb in the solenoid?
To C4 line lock , how to
